First post, by JustRob
So, usually PC cases have 1 pin connectors for stuff like power LEDs, to be hooked up to the pins usually in the bottom right of the motherboard.
My case doesn't. It's a silver colored Vobis ATX style case, and it has them for the power switch, HDD led, and reset switch, but the power LED itself has this 4 pin connector, with both a female and a male end. I tried to plug in a 4 pin connector from my PSU into the male end, didn't work. I tried to plug the female end into my IDE hard drive or CD-ROM drive, followed by a 4 pin connector from my PSU into the male end. Didn't work.
I have no idea how to get this thing working. Has anyone ever seen something like this?
