First post, by majestyk
- Oldbie
I recently found a GA-586HX (early revision 1.53) in very good condition. So I started experimenting with different CPUs.
To get a Pentium MMX 233 running the latest BIOS (2.9) had to be installed. Then I did the "BF0 mod" to pull up the BF0 pin to Vcc when the DIP-switch is open.
This worked well and the CPU is being identified by the BIOS correctly, the multiplier setting x 1.5 is interpreted as x 3.5 and the automatic voltage detection makes the VRM-transistor deliver 2.9 V core voltage.
While I was looking for a Vcc3 pin at the CPU for the BF0 mod I found the voltage to be at 3.3V but there´s no direct connection to the 3.3V regulator at the upper-right corner of the board!
So where the hell does the 3.3V I/O-voltage for the CPU come from?
I just found the answer myself: If Jumper JP4 is present (and no automatic detection for Split-Voltage CPUs and Core Voltage) JP4 is jumpered so that there´s a double bridge between 3.3V from the regulator and the Vcc3 pins at the CPU socket.
With automatic detection - which is the case here - JP4 is not populated and the 3.3V I/O voltage is switched by the semiconductor In the red circle (probably a MOSFET) by the BIOS autodetection circuit.
