First post, by Solo761
Hello all, first time writer, long time reader 😀.
Short story:
I have one socket 7 motherboard that I'm playing with (QDI Titanium IB+, 64MB SDRAM, Pentium 150 at the moment, I plan to use MMX 233, but this one has cooler glued on so until I get one for MMX this one will do 😀). I've made PS/2 to AT keyboard adapter ( i had only PCB PS/2 socket at hand, don't laugh :p) that works fine with one keyboard (probably the newest, from 2013, has lowest current rating at 50 mA, basically cheap no name keyboard), but two older ones, Logitech Classic Keyboard Y-SM48 (100 mA) and 2000ish BTC-5201 (170 mA) don't work with only LEDs on them flashing.
Logitech flashes its LEDs on power on and after that they only flash, and BTC one works until I press for example Num Lock (or until boot process tries to turn it on) and from that moment keyboard doesn't work and that LED keeps flashing. Cheap one works fine regardless of LEDs . All of them work fine on something newer I tried them on (Fujitsu Siemens S400 Thin Client).
Has anyone had similar experience? And know what could be the issue here?
I didn't find AT port specification, only for PS/2 that states that PS/2 and IBM AT keyboard ports are the same logically and electrically, and PS/2 port is 5V 275 mA.
Could motherboard capacitor age be the reason? They're Licon brand, 85°C, but they're not bulged or have any other defect I could notice visually.
I've tried checking Vcc pin on AT connector, it's at 5.3V, clock and data pins are at 4.82V.
I have replacement capacitors I could use, mostly nichicon and rubycon from RSDelivers, so they should be the real thing, not fakes. But if something else could be an issue...?
So far I haven't done anything "serious" with this motherboard so can't tell if it's stable or not, but so far in these experiments it didn't crash or freeze.
I'm open to suggestions 😀
