Making a BTX cooler adapter
First post, by Robertkopp
I have bought 2 btx boards and despite having a cooler, getting a btx case to mount it to is not an option.
I have a 3d printer so I will be making a backplane for sure, but making a adapter to mount a different heatink/cooler is also on my mind.
I'd like to hear about some suggestions! I was thinking about some slim AM2 heat pipe tower.
Maybe something like this
https://archive.org/details/@robertkopp
Reply 2 of 25, by Tetrium
Grem Five wrote on 2022-02-10, 00:30:
If I may ask, why is "getting a btx case to mount it to is not an option"?
Only thing I can think of is lack of space.
Or shipping is too expensive.
I'm glad BTX never went anywhere, it was really not much of an improvement compared to the AT to ATX switch.
For me BTX these days is mostly just one extra thing to keep in mind when browsing stuff 😜
My retro rigs (old topic)
Report spammers here!
Reply 3 of 25, by Robertkopp
Hey nice to see a reply on my thread. I found the btx list in the forums after my post, I ordered a whole dell dimension 5150 for 10$ just a few minutes ago. I think I have to cut out the io plate tho it's stamped into the case it seems.
So one of the Win98 pcs is complete, now I have 2 more of these boards.
I think a modern cooler with heatpipes would be real nice on a pentium d or celeron d.
And also I just had the revelation after ordering that you can mod a atx case with top power supply and swap the power supply with the expansion area. Drilling new holes for the motherboard and the cooler is the smaller task.
And the main reason is that most of these cases are just to ugly for my setup. The only one I'd really like to display is the dell xps 720 case.
Reply 4 of 25, by Doornkaat
I don't understand: Do you need a special adaptor for coolers in BTX cases? Do the motherboards not use the retention points specific to the socket?
I have little to no experience with BTX hardware obviously.😄
Reply 5 of 25, by Grem Five
There are btx cases out there, most common ones are some dell cases.... they made a crap ton of btx systems. I have a cooler master 820 stacker ( I think it's a 820 ) that supports btx along with atx.
i hate most dell cases but i like some of the btx ones i have, mine are dimension e520s.
<edit> Mine is actually a 830 stacker but has the option to be setup in btx config.
Reply 6 of 25, by Grem Five
Tetrium wrote on 2022-02-10, 00:53:
Only thing I can think of is lack of space. Or shipping is too expensive. […]
I dont know.... btx boards are laid out a bit different than atx but the new systems I have built over the last few years I wont buy a case unless I can invert the motherboard, I prefer that orientation.
Reply 7 of 25, by Robertkopp
Doornkaat wrote on 2022-02-10, 09:00:
The mounting points are in the case, you screw the cooler on top after you installed the board. A btx cooler has very long mounting screws because of that, there is no way to just put a washer and a nut on the back and call it a day.
Reply 8 of 25, by Errius
Grem Five wrote on 2022-02-10, 15:19:
I was going to comment on this. The Stacker 820 is astoundingly rare. In fact I'm not sure if it ever existed outside of press photos.
ETA: spec sheet
    RC-820.pdf.rar
    501.91 KiB
    36 downloads
Is this too much voodoo?
Reply 9 of 25, by Doornkaat
Robertkopp wrote on 2022-02-10, 17:03:
The mounting points are in the case, you screw the cooler on top after you installed the board. A btx cooler has very long mount […]
Ah, ok, got it! 👍
Good idea in theory though not actually practical. I wonder why Intel didn't just rotate ATX 180° like some case manufacturers do anyway.
Reply 10 of 25, by Robertkopp
I just bought a old Dell XPS710 and found out that the 730 is actually a flipped atx layout. And there is a somewhat clean mod on youtube to make it atx again.
The guy just needs to calm down with his angle grinder.
Modding that case and especially the btx variant was apperantely a thing in 2006 or when this came out . Most of the btx prebuilds have a removable motherboard tray with a complete i/o shield and extension bay mounts attached.
Get out the tray, flip the back and attach it again.
Reply 11 of 25, by The Serpent Rider
Rotate what? ATX standard does not include any particular orientation in space.
Reply 12 of 25, by Robertkopp
Errius wrote on 2022-02-10, 18:42:
ETA: spec sheet
I just found a stacker, is it worth 65$ and a 2 hour drive? He sells the nvidia variant with all the parts and filters in good condition. Looks real sick to be honest.
Reply 14 of 25, by Robertkopp
Errius wrote on 2022-02-13, 22:26:
This is the green Stacker 830 with Nvidia branding? That looks cool and I would buy it if it was near me.
Yes it is brother, I hope I still get the chance. I have to borrow a car to get there. Thank you for the nice tip.
Reply 15 of 25, by Grem Five
Robertkopp wrote on 2022-02-14, 03:08:
I would make sure he still has the BTX pieces that should have came with the case. If he threw out the cpu cooler mounting bracket you would be right back to square one.
I went and checked mine and its actually a 832 stacker and they did not come with the optional mounting bracket and such. According to the manual the 830 came with the optional BTX kit, the 831 did not nor did the 832 but the 832 ( and 830 ) did come with the optional cross flow fan brackets although I still have never been able to find one of those cooler master cross flow fans.
Other than that the 830, 831 and 832 were all the same chassis just different accessories included. Mine is actually just like this one the war machine. A year or two ago an ebay seller was selling like a hundred of these new in box or new old stock.
Reply 16 of 25, by Errius
I only have one of these cases, a 830. It came with the plastic BTX duct (in two pieces) but was missing the motherboard mounting bracket, which must apparently be purchased separately. I imagine getting hold of one of these is going to be hard given how short-lived BTX was. Very few of these conversion kits would have been produced.
Reply 18 of 25, by Doornkaat
The Serpent Rider wrote on 2022-02-13, 20:53:
Let me demonstrate:
4.23 KiB
rotate 180°
4.42 KiB
Get it now? 🙂🙃
Reply 19 of 25, by Grem Five
The metal piece on the second pic should be the btx mount or what do you think?
Yes that metal piece should be the btx mount it bolts to holes in the motherboard tray. I don't have one but from the manual that is what the btx mount looks like.
