Thoughts on k6-233 on socket 5
First post, by Sphere478
Who all is running a k6-233 on socket 5?
How’s the fet holding up?
Did you make a hole or cut the key pin?
How’s it working?
I know several of you guys/gals have done it. How’s it workin out?
Sphere's PCB projects.
Reply 1 of 32, by Sphere478
https://www.ebay.com/itm/162771815822
Maybe an alternative to pin cut/hole drill?
You’ll still have to drill the 321st hole in the adapter though.
Reply 2 of 32, by Anonymous Coward
You've got to be totally crazy to install a split rail 2.9V K6-233 into any unmodified socket5 board without using an adapter.
Reply 3 of 32, by Sunoo
Anonymous Coward wrote on 2022-03-14, 02:49:
Based on what I’m seeing, 3.2v K6-233 chips seem to exist though?
Reply 4 of 32, by Sphere478
It’s 3.2v core 3.3v I/O (there may be lower volt versions also, I’m not talking about them)
Reply 5 of 32, by BitWrangler
They basically pull double the power than socket 5 is rated for, a lot of socket 5 won't handle a P-200 because they don't have the amps at the reg. Set it for like 166 and power it with one finger on the reg and one finger on the power button, if it gets ouchy, turn it off.
Reply 6 of 32, by Sphere478
BitWrangler wrote on 2022-03-14, 03:20:
I agree with the finger method 😀 very wise precaution.
I think it will work fine in most cases though 😀 I’ve heard of several people doing it successfully.
Looking the fet specs up prior to the attempt is a good idea, and not too hard.
Reply 7 of 32, by BitWrangler
Single plane socket 7 will often manage it, don't confuse that with socket 5 though, which you may have to socket trick or mod to get the multipliers.
Reply 8 of 32, by mwdmeyer
I believe WinChip2 is single 3.3 (or 3.52?) voltage and should work in Socket 5 without modification. It even has 3dnow, its a pretty fast chip.
Reply 9 of 32, by Repo Man11
If you haven't already, you'll probably want to watch this Necroware video where he (among other things) replaced the voltage regulator to upgrade the CPU on an early Socket 7 FX chipset board.
https://www.youtube.com/watch?v=CMiGVQbMC5U
Reply 10 of 32, by Sunoo
I find the WinChips super interesting. I thought I was buying a WinChip2 based PNY QuickChip, but it turned out to be a C6 in it, and it also seems to either have problems (possibly just with my motherboard?)
I thought an interposer would be needed for one, but maybe not? Sounds like it was sold in both 3.3v and 3.52v varieties, though eBay seems to only have the 3.52. And unfortunately my motherboard has no voltage settings.
It does have a socketed VRM board of some sort, though it’s clearly not a standard one as it has too few pins. Maybe something could be done there, but I’m not sure it’s worth the effort to try to get a replacement made. I’ll check out that YouTube video later though.
Reply 11 of 32, by Sphere478
Repo Man11 wrote on 2022-03-14, 04:01:
Yassss!! We need those things for sale (but a beefier version). Very fun video
Oh cool, that’s a switching regulator. (Less heat/more efficient)
Interesting find for a socket 5 board..
I understand the winchips were kinda the go to for high speed socket 5, I was curious (for this thread) specifically about a k6 233 in socket 5 though
The k6-233 probably gives even the fastest winchips a run for their money doesn’t it?
Higher speed winchips are hard to find btw. (And expensive)
Reply 12 of 32, by Anonymous Coward
Ha, I forgot the K6-233 was 3.2v not 2.9v like the other ones. It still doesn't change the fact that installing one might burn traces and/or the VRM.
Even on socket7 boards designed to handle it, a lot of people didn't want the 233 because it ran way too hot.
Reply 13 of 32, by Sphere478
Anonymous Coward wrote on 2022-03-14, 06:08:
I’d give it a whirl with mine if I had a socket 5 mobo 😀
What would you recommend as a good alternative. Mmx200 overdrives are the obvious go to aside from winchips, but fast winchips are rare, pentiums are better, and overdrives are pricy.
Reply 14 of 32, by H3nrik V!
One thing is the VRM/FET, another is if the traces on the PCB can handle the extra current, which may be doubtful if the regulator needs to be upgraded in order to handle it ..
Reply 15 of 32, by Sphere478
H3nrik V! wrote on 2022-03-14, 06:35:
are there actually reports of people doing this (with a 233), or are we over thinking?
Because I’ve actually heard of several people successfully doing it. (I’m hoping one of them chimes in)
“Sometimes the problem isn’t the problem, sometimes the problem is your attitude about the problem”
😀 you may be right. I wanna see reports, data, talk to people. Prove it to me, no speculation of doom and gloom! :p
Pull out a mobo and show a heating trace on a thermal camera, let’s look up the ratings of these fets, take temp readings. Data! First hand! Let’s get scientific! 🧪 🧫 🧬
Reply 16 of 32, by Anonymous Coward
Sphere478 wrote on 2022-03-14, 06:17:
You're kind of limited to overdrives and fancy VRM modules.
If you can't get either of those, you're probably best just leaving it alone or maybe a P166. I don't think the K6-233 is going to be a meaningful upgrade over a P166 anyway.
Reply 17 of 32, by H3nrik V!
Sphere478 wrote on 2022-03-14, 07:01:
are there actually reports of people doing this (with a 233), or are we over thinking? […]
I hear you! 😀 But after 15 years of PCB design with a bachelor degree in electronic engineering, I'll argue that I have a bit of qualified background to assume from 🤣 But agreed, let's see what we have and work from that. If the regulators are dimensioned for a lot more power than a 166 P54C, then it's very plausible that PCB traces are as well. OTOH, if the regulators are only dimensioned for juuuust exactly what it needs, chances are that PCB traces may have been cut, in order to route other signals etc.
Reply 18 of 32, by rmay635703
I tried an IBM PR233 in an old Socket 7 at 66mhz FSB (166mhz clock) and even after adding additional cooling to the linear VRM it still would overheat and crash.
I’ve often thought a little universal kit should exist for converting/ upgrading linear motherboards to switched replacements
Something else rarely seen was modding a single rail board by simply making the vrm output a lower single plain voltage, a PMMX runs just fine at a 3.0volt univoltage
Ah well pipe dreams
Reply 19 of 32, by BitWrangler
The Winchip problem in general is that with a C6 which is only about 0.66 the performance of a Intel CPU, is that while it's low wattage for the clock, you only get about the same actual computing power per watt. So the fastest C6es are not really an upgrade over a P-166. The Winchip 2 and 2A do a bit better, but for a given power limitation it's still a pretty minor upgrade vs fastest intel CPU with that power limit. If you're stuck with multipliers up to only 2x and can get a 75mhz bus then a PR200 cyrix/ibm 6x86 with an official 2x75 will work, when your official max on the P54 is P133, that's an upgrade, but then you can run a late P-133 at 150 very likely, which makes it a wash.
