First post, by Kahenraz
- l33t
Windows 95 and 98 have a tick box to uncheck "Suggest MS-DOS mode as necessary" in the Advanced properties of DOS programs, but this option does not appear in Windows ME. Without it, Windows suspends some DOS applications when they are run with this annoying popup. There is a delay when dropping back to Windows, having to close the dialog, then select the window and set it back to full screen. This is particularly tedious if I have both hands on the keyboard as dismissing the dialog and selecting the Window is best done with the mouse.
Is there any way to restore this functionality to stop the dialog from appearing?
