First post, by Boohyaka
- Oldbie
Hi there, quite a common topic, I've done quite a lot of reading but I'm just not sure anymore and prefer asking again.
I have a Promise S150 TX4 PCI card on a Win98SE PC. Using a 120GB SSD for the OS, and and additional 500GB HDD.
I have partitioned and formatted the drives on a modern PC with Rufus, as Large FAT32. All is well. OS installation was no problem, and overall the computer runs perfectly fine. Yet I have a few glitches and related questions.
- Obviously the PCI card allows to circumvent the potential motherboard/bios HDD size limits. But does Win98SE have its own limits one way or another with bigger drives, even if using a PCI controller and proper drivers?
- I have this weird issue where on boot scandisk will trigger and complain it's not able to read the last cluter of drive C (the 120GB SSD, the OS drive). By reading some other posts, it seems that's probably because I partitioned the disks using Rufus on a modern system. Reinstalling the OS is not an issue if I can make it right this time, so should I grab FDISK and Scandisk from Windows ME as I've seen suggested and use those instead? Will they support my 120GB and 500GB drives?
- Not related to Win98 this time but only on the Promise S150 TX4 card: I actually have two of them, bought separately. Both mention BIOS 1.00.0064.48 on boot and I find it strange as I find no mention of this BIOS on internet, and even on Promise's website the latest BIOS update doesn't really make sense, as it's numbered way lowered than that? Anyone got a clue?
- With both cards, on two different motherboards with different drives, the same issue randomly appears: the card won't detect one, or both drives on boot. Usually a simple reboot solves it and all is fine again. Not a (very) big deal, but that issue was the reason I started looking into BIOS updates, as per previous question.
Cheers
