First post, by cinix
I have a 486 PC I recently bought and I've been trying to back up the hard drive. I don't own any other PC's with IDE ports, or have any other IDE hard drives I could plug into it, which made it difficult. My first attempt was to hook up my laptop and use interlnk/intersvr to transfer the files with xcopy. It was painfully slow, but would have been fine if the PC did not keep freezing.
I eventually found xxcopy16 which let me resume quickly from where I left off after each time it froze. I could copy a couple files, it would freeze, I would reboot and start again. Sometimes it froze right away, other times it might run 10 minutes. It took many days but eventually I made a copy of the drive.
Now I'm trying to understand why it's freezing, and I'm at a loss to how to start debugging the problem. I tried experimenting by enabling/disabling different CPU caches, and I tried running some slowdown programs, none of which helped.
I purchased an IDE-to-SD card adapter thinking that the freezing may just be caused by the interlnk software, but that didn't turn out to be the case. When copying files from the original hard drive to the new "SD card" hard drive I experience the same freezing. I tried running scandisk on both the original hard drive, and the SD card, and they each lock up during the surface scan.
Most of the time when the system locks up a red light on the front of the PC turns on, does that help me or is that a generic error? The motherboard is a UC4914-G (rev 1.0) with a CPU i486 DX2, and 16 MB of RAM.
I'm hoping what I'm describing is common enough that someone may know what is happening, or could give me some pointers.
