First post, by eyalk4567
Does someone knows if Intel D850GB motherboard (Pentium 4 Willamette
) can use a modern PSU?
Before a few days, I opened up my PSU to clean it, as it was quit dusty from the inside and after I opened it I saw it had a few bad capacitors inside (also I had 2 GPUs going bad on me on this PC so I thought maybe I should looking inside the PSU to check it as the capacitors on the motherboard looked fine).
So I thought about buying a new modern PSU or to give it to someone to replace the capacitors on the PSU.
So my question is, should I buy a new modern PSU or fix it?, as the current old PSU got a high 5v (35A) line and I'm not sure if I need a high 5v line for a Pentium 4 Willamette.
Also because its a Pentium 4 Willamette the motherboard got that 6 pin auxiliary power connector and the old PSU right now doesn't have it so I'm using an adapter to connect it from the 20 pin PSU connector to the motherboard so I think I can use it also on a new PSU as they got 20+4 pins.
My specs:
CPU: Pentium 4 Willamette 1.9GHz
Motherboard: D850GB
RAM: RDRAM 512M PC800
GPU: Right now an Nvidia MX440 and in a few months I'm going to change it to an Nvidia Geforce4 TI 4400 128MB
Storage: WD400 40gb
Sound Card: Sound Blaster live 5.1
