Reply 20 of 22, by The Serpent Rider
- l33t++
Also you can't use one module, due to 16-bit data bus width per module, similar to how Pentium SIMM modules were used.
The Serpent Rider wrote on 2022-04-30, 12:50:Also you can't use one module, due to 16-bit data bus width per module, similar to how Pentium SIMM modules were used.
That's also true, I thought at least 2 modules were used.
Nemo1985 wrote on 2022-04-30, 12:45:Kindly reminding to you good people that the rdram needs terminators when memory slots are unpopulated.
I am aware, when I say using "one or two modules", I mean one RIMM and one C-RIMM per module. All possible combinations on the most probable contender, the i840 result in a non-POST.
Here, the density of bits per memory chip ( 576 Mb per chip in the case of ECC) is the issue as it is not being detected by the Intel chipsets.
