First post, by AlessandroB
I have one SX807 that is "SL" version but not WB, instead SX955 is "SL" and also WB. So it is the one to have?
Reply 3 of 12, by Anonymous Coward
I don't think that's true. Intel made 3.3V DX/2s as well. They shared silicon with the DX/4, even retaining the 2X/3X multiplier selection.
Reply 4 of 12, by liqmat
AlessandroB wrote on 2022-05-15, 10:26:
Hi AlessandroB,
Just a side note, but I had a recent interesting experience with those two DX2-66 variants. I upgraded a small 486 system board with the SX807 and all worked normally, I then tested out a SX955 variant on the same board and de-turbo mode would hard freeze the system. After a CMOS reset I stuck the SX807 back in and the turbo toggle worked normally again. Now, this might just be a faulty SX955, but if anyone reading this has a setup where they can test this I would be interested to see if they experience the same thing.
(っ•́。•́)♪♬
Reply 5 of 12, by pixel_workbench
Doesn't the WB cache require support from the motherboard? The later 486 boards have that option in the bios, but they also support faster 3.3v processors.
My earlier board that only supports 5v processors does not have that bios option to toggle WB/WT cache.
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 6 of 12, by liqmat
pixel_workbench wrote on 2022-05-15, 16:06:
In my case the motherboard has the WB/WT toggle, but only supports 5V CPUs.
(っ•́。•́)♪♬
Reply 7 of 12, by AlessandroB
liqmat wrote on 2022-05-15, 15:44:
Hi AlessandroB,
My Sx807 work with the 3,3v regulator plugged-in
Reply 8 of 12, by waterbeesje
To me the SX955 is the ultimate DX2-66.
I've got three of them.
They all do run fine art 3,3v and without fan they keep cool to the touch.
WB does require bios support. If the bios does not explicitly support it, chances are high the CPU runs WT (nothing wrong with that, runs just fine, but a waste of the capability).
Performance is about 5% higher on three boards I have, compared to a regular wt dx2.
Stuck at 10MHz...
Reply 9 of 12, by AlessandroB
waterbeesje wrote on 2022-05-15, 19:06:
To me the SX955 is the ultimate DX2-66. I've got three of them. […]
and what about the “sl” capabilities?
Reply 10 of 12, by waterbeesje
AlessandroB wrote on 2022-05-15, 19:23:
To be honest, I've never noticed any performance difference for SL and never really dug into it. All I know about SL is it uses some energy optimization but that's about it
Stuck at 10MHz...
Reply 11 of 12, by liqmat
And do your SX955 CPUs operate normally (slower) with turbo off? I am still testing on the board I have, but in all my years I've never had this particular issue so trying to narrow down the problem.
(っ•́。•́)♪♬
