First post, by Sphere478
- l33t++
Anyone able to design a 3d print that allows me to gut a gotek and install it in a card slot?
Would be nice to have the oled and rotary dial also.
My new case doesn’t have drive bays.
Sphere478 wrote on 2022-05-27, 07:15:Anyone able to design a 3d print that allows me to gut a gotek and install it in a card slot?
Wouldn't it be super inconvenient to have to reach behind the case every time you want to swap disks?
Sphere478 wrote on 2022-05-27, 07:15:My new case doesn’t have drive bays.
Wait. Why in Wayne's Worl.. , err, why on earth would anybody do that? 🤷♂️
Designing a PC case without any drive bays, I mean.
How to install a fan control, a card reader etc?
Especially card readers must be replaced every few years, due to them becoming obsolete.
At least a 3,5" slot is a must-have feature, isn't it? 🙂
Hm. How about using a long FDC ribbon cable and an external enclosure?
There are some 3D printed Gotek chassis for the Amiga / Atari platforms.
Be careful with the power, though.
A separate PSU coukd cause trouble with ground loops etc.
Maybe using the 5v from USB? If the chassis has a spare USB connector from its hub..
Making an DIY USB to FDC-power cable should be doable.
appiah4 wrote on 2022-05-27, 07:56:Sphere478 wrote on 2022-05-27, 07:15:Anyone able to design a 3d print that allows me to gut a gotek and install it in a card slot?
Not really 🤷♂️ Easy to reach.
Jo22 wrote on 2022-05-27, 08:10:Wait. Why in Wayne's Worl.. , err, why on earth would anybody do that? 🤷♂️ Designing a PC case without any drive bays, I mean. […]
Designing a PC case without any drive bays, I mean.How to install a fan control, a card reader etc?
At least a 3,5" slot is a must-have feature, isn't it? 🙂Hm. How about using a long FDC ribbon cable and an external enclosure?
Modern cases are ditching the bays. Usb and 2.5” handles everything these days
Actually, what about putting it on the atx I/O
Could 3d print a rear i/o shield with a 3-1/4 bay on it
Sphere478 wrote on 2022-05-27, 07:15:Modern cases are ditching the bays. Usb and 2.5” handles everything these days
Idea #2 (or #4), as my father would say - get a jigsaw and make the case have a 3,5"drive bay (aka fix the damn case). 😁
Edit: Or a Dremel tool, not sure.
Anyway, not sure what else to say.
Slot brackets for SD/CF adapters exists, but for Goteks.. Not sure. Maybe it's possible to use the bracket of an old USB controller card
and screw the Gotek to a Veroboard or any other board? 🤷♂️
Edit: Fixed the quote.
Yeah, I was thinking a 3d print would be best
It could be made to tab into the slot and mount the gotek guts well and centered
