First post, by MRVFONE
Hello,
I have a LPX Motherboard from a Samsung Sensor 386 SX 16 PC. It was the 2nd 386 i ever owned back in the day when i was a kid. So a few years ago i saw a motherboard from one of these PCs for sale so i jumped on it. Unfortunately its case had already been binned.
Its a Intel 386 SX 16 MHZ soldered to the motherboard. Chips set is VLSI 9110AV / 9110AT and Chips and Tech F82c710. It has a WDC WD90c11 VGA onboard... but i think its just a stock ISA version.
I have been trying to find datasheets on the main VLSI chips with no success. I was hopeing maybe some one has a 386 motherboard based on the same chipset. Or close to it.
I don't know is Samsung built the motherboard.. or some one else did for them.
I have attached a pic of the motherboard and a copy of its dumped BIOS image in case that's useful to some one.
I have looked through the Mr BIOS achive with no luck.... BUT i wasn't expecting to find a bios for a board so old.
Thanks for any help, Tim.
    SAM386.rar
    25.75 KiB
    57 downloads
    442.2 KiB
Reply 1 of 12, by darry
The BIOS ROM contains the following text :
Phoenix Technologies  ROM Based Setup Program  Written by Eric A. Shoaf-Enge
Phoenix Technologies Ltd.
System Configuration Setup V4.02
and a quick Internet search for "Eric A. Shoaf-Enge" returns this :
https://www.whitepages.com/name/Eric-A-Enge/S … -MA/Pr84gra2W3j
Whether this is the same person as the one referenced in BIOS, whether the contact info is still current, whether that person would take kindly to being contacted about this and, finally, whether he could provide any useful/interesting info are all open questions .
Reply 2 of 12, by MRVFONE
Well looks like i read the chips wrong!! OPPS! its actually a VL82C320 and a VL82C331 !!! Thanks guys for noticeing this.... now i might find more info! Maybe even its "Name" of the chipset....
9110 must be the date code? 10 week 1991 ??
Tim.
Reply 3 of 12, by mkarcher
MRVFONE wrote on 2022-05-31, 07:13:
You should find more info now. That's the TOPCAT chipset by VLSI, in the "SX" variant, datasheets are available on the Interwebz. These chips were later licensed to Intel and also manufactured as Intel 82343 and 82344.
Reply 4 of 12, by MRVFONE
// 80386 BIOS Version 3.10 Rev. 2.06 (BIOS not original, works in PEM 2530)
// additional info from chukaev.ru54.com: CPUBT-S26361-D548 (Siemens?) - Chipset: VL82C320A, VL82C331, VL16C452B - CPU: NG80386SX-20, socket for 80387SX
ROM_SYSTEM_BIOS(1, "pem2530", "DTK PEM 2530")
ROMX_LOAD( "386-dtk pem-2530-high_32k.bin", 0x10000, 0x8000, CRC(56a822c0) SHA1(b65797c0f87a0815b393758af9c059e6d7172ae9), ROM_SKIP(1) | ROM_BIOS(1))
ROMX_LOAD( "386-dtk pem-2530-low_32k.bin", 0x10001, 0x8000, CRC(8688d883) SHA1(c3034c8b343786cb89de48fb2f4992160414f89e), ROM_SKIP(1) | ROM_BIOS(1))
I found this in Mame Source. https://github.com/mamedev/mame/blob/master/s … /drivers/at.cpp
But i can't find these 2 files in pem2530.zip ?????
Tim.
Reply 5 of 12, by Anonymous Coward
I'm pretty sure MR-BIOS for Topcat SX is available.
Reply 6 of 12, by MRVFONE
The issue i'm seeing is not all BIOS support the com/lpt/ps2 etc ports expansion chip that my board has with it. So i'm trying to find as many as i can and see what works.... i'm trying to download the full mame copy to see if it has these bios file in it. So far i have been unable to find anywere free that i can just download both files....
Reply 8 of 12, by rasz_pl
pcem_v10_clean_roms_pack.7z\pcem_v10_clean_roms_pack\roms.zip\dtk386\3cto001.bin
NEAT CHIP SET CONFIGURATION
DTK Corp. 386sx COMPUTER
DTK 386sx Chipset ROM BIOS Version 4.26
(C)1988/90 Datatech Enterprises Co., Ltd.
#96120590N
so probably not the file you are looking for
here is teh PEM one Re: 80386 BIOS image collection
Reply 9 of 12, by Horun
Found the Samsung Setup and memory driver for Sensor 386, uploaded to Vogons with my collection of old Samsung stuff: http://www.vogonsdrivers.com/getfile.php?file … 963&menustate=0
SETUP386.EXE 19,917 Setup Program Samsung Sensor 386
MEMSP386.EXE 24,651 Memory Manager Sensor 386
Inside the Setup.exe has:
" Phoenix Technologies ROM Based Setup Program Written by Eric A. Shoaf-Enge .9.X... Phoenix Technologies Ltd. .. System Configuration Setup V4.02"
Reply 10 of 12, by Horun
Anonymous Coward wrote on 2022-06-01, 08:33:
Sorry to necro but have not found any MR TOPCAT bios, if you have a link would be nice 😀
Reply 11 of 12, by Anonymous Coward
V019B301 VLSI301 VLSI TOPCAT / Intel-340 386 SX/DX, non-cache
V019B302 VLSI302 VLSI TOPCAT / Intel-340 386 SX/DX, non-cache, with 82C106 combo chip
V019B312 VLSI312 VLSI TOPCAT / Intel-340 386 SX/DX, 385 cache, with 82C106 combo chip
These notes indicate the ROMS are for both the SX and DX version.
I assume your board is cacheless, so try the first one.
Reply 12 of 12, by majestyk
There are 3 different files for 3xx and 3 for 4xx VLSI Topcat. The files should be easy to find in the common MR BIOS collections :
46.61 KiB
They are all 64K, so need to be split here for 2 x 32K EPROMs.
