First post, by Croccy22
Hi all,
I have just acquired a Fujitsu-ICL PCTV, but it doesn't have the remote control.
I have found a manual way of switching between the TV and the PC inputs, but so far I have not discovered any method of switching to either the Scart input or the Composite input on the back. I am guessing this is a button that can only be found on the remote control.
It's a long shot but does anyone here own one of these that has the remote control for it? Firstly I would like to know how you actually switch to the Scart input via the remote. Secondly, maybe we can find a way of capturing the codes so we can program them into a universal remote solution.
I am also investigating things from the software side, as it appears to load a DOS TSR into memory that listens for the remote control signals and then calls a windows .dll file which sends an I2C command to the controller inside the unit. I'm hoping I may be able to discover a way of just calling those routines without having the remote present.
Thanks, Matt.
