First post, by Skip94
Hi all
I recently picked up a floppy controller to use in my 286 4 floppy build (360K, 1.2mb, 1.44 and Gotek).
I grabbed it because it has a built in BIOS and the option to be jumpered to the secondary IO address.
Currently having some issues though. Upon boot up I get a display saying both A and B drives are 1.2Mb, despite being set in the Bios as 1.44 and 1.2Mb.
So I presume the BIOS on the floppy controller is set incorrectly. But I have no idea how to change it! I read the EPROM on my TL866, hoping that there'd be something visible on it with instructions for changing it, but no such joy.
There are jumpers to set the drive type on the card, but the card BIOS seems to override these. It also seems to overide the address jumper.
If I disable the card BIOS, it works perfectly, but then I believe I need a special driver to get DOS to recognise the 3rd and 4th drive. Maybe this is a better way to go, but can anyone tell me what driver I require, googling seems to suggest driver.sys, but I can't seem to find this?
Andrew
Reply 1 of 13, by Grzyb
I think I tried to use such a card as Secondary FDC, and failed...
but it was many years ago, before this - https://forum.vcfed.org/index.php?threads/dos … c-driver.74244/
Looks like it's worth to give it a try...
Żywotwór planetarny, jego gnijące błoto, jest świtem egzystencji, fazą wstępną, i wyłoni się z krwawych ciastomózgowych miedź miłująca...
Reply 2 of 13, by Skip94
Thanks. I'm hoping if I can get the drives picked up by a BIOS, then getting DOS to see them should be easy. I've just come across Sergey Kiselev's floppy BIOS, which I'll give a try when I'm home from work.
Cheers
Andrew
Reply 3 of 13, by maxtherabbit
The BIOS on that card does not override the jumpers. It reads from them at startup. However, the BIOS on that card also requires that it be set as the primary FDC. If you wish to use it as a secondary FDC you must use the main system BIOS to control the primary FDC and disable the LCS ROM. Then to access the drives on the secondary FDC you can use my DOS driver found here:
https://forum.vcfed.org/index.php?threads/dos … 244/post-919840
Alternatively if you can get your hands on a MR BIOS for your motherboard it can manage all 4 drives on both controllers simultaneously (in theory, I've not gotten it to work)
Reply 4 of 13, by maxtherabbit
Skip94 wrote on 2022-06-30, 01:46:
Cheers
Andrew
To the best of my knowledge no option ROM (including S. Kiselev's) exists that can manage a secondary FDC.
Reply 5 of 13, by Horun
I agree with Max ! Have a couple of BIOS driven 8bit floppy controllers for XT and early AT that support HD floppies but it must be set as the Primary.
fixed a typo, One of my cards supports 4 floppies but that does not matter as the add-in card overrides sort of like a scsi adapter with it's own bios .;p
Reply 6 of 13, by Skip94
All good thoughts, thank you.
Sergey's BIOS does seem to support a 2nd floppy controller, according to the documentation. I had a little play this more and made some progress. I had to hex edit the values in as for some reason the config utility can't write to the EEPROM, but the photo below shows what I have so far.
Next I think I need to add some bits to my config.sys file, then DOS should pick the drive up.
Reply 7 of 13, by maxtherabbit
Skip94 wrote on 2022-06-30, 06:37:
That's awesome that his BIOS supports secondary FDC, but you're going to have to edit it further to tell it both FDC are at IRQ6/DMA2. The LCS card is hard wired to those (as are 95% of FDC) and they can be shared with proper port writes to the respective DORs (if Sergey's BIOS does this)
As far as DOS, once you've got BIOS support you just need to add a DEVICE=DRIVER.SYS line for each drive in the CONFIG.SYS
Reply 8 of 13, by Skip94
maxtherabbit wrote on 2022-06-30, 13:15:
That should be easy enough, I actually set them to separate IRQ and DMA's, as I didn't want to cause a conflict. I'll happily admit, I'm still very much a novice when it comes to this stuff.
I'll write a config.sys file tonight.
Cheers
Andrew
Reply 9 of 13, by Grzyb
What's DOR? Some register?
Once upon a time I tried to install two FDCs, but no luck: the very presence of Secondary FDC caused the Primary to fail.
I blamed it on IRQ and/or DMA conflict, and assumed the Secondary must be set to different IRQ/DMA - impossible with generic multi-I/O cards, but possible with eg. AHA-1542B.
Reply 10 of 13, by weedeewee
Grzyb wrote on 2022-06-30, 17:09:
Some generic multi IO cards do actually allow one to set the FDC to the secondary port, same for the IDE, for example the Goldstar Prime 2 https://arvutimuuseum.ee/th99/c/E-H/20334.htm
Do not ask Why !
Reply 11 of 13, by Grzyb
weedeewee wrote on 2022-06-30, 17:46:
I/O address can be changed from 3F0-3F7h to 370-377h.
IRQ, however, can't be changed, it's always 6.
DMA can't be changed, either, it's always 2.
AHA-1542B allows to change I/O address to 370-377h, IRQ to 10, DMA to 3.
Reply 12 of 13, by maxtherabbit
What's DOR? Some register? […]
Yep. Digital Output Register. Selects drives, turns on motors, and controls whether IRQ/DMA is enabled on the controller.
http://www.isdaman.com/alsos/hardware/fdc/floppy.htm#DOR
By toggling that bit on and off in the two FDC situation you can effectively "share" the IRQ/DMA by ensuring only one FDC is using them at a time. Again this is all contingent on whether S. Kiselev's ROM has this functionality coded.
Reply 13 of 13, by Skip94
No joy yet sadly. I have just ordered the bits to build myself Sergey's "Monster floppy" controller thats seems to allow up to 4 drives per controller. More for interest than anything. I'll continue playing over the weekend.
Andrew
