486 - Not detecting floppy and HDD?
Reply 20 of 22, by weedeewee
Greger wrote on 2022-07-30, 20:03:
jakethompson1 wrote on 2022-07-30, 19:49:
weedeewee wrote on 2022-07-30, 19:41:
also try issuing the " fdisk /mbr " command, since in the photo it mentions unknown IPL for the MBR bootrecord.
yes but this could cause a mess when the boot disk is for a different version of windows, no?
Yes it did. Now it says that the operating system is missing in English instead. Oh well. Probably the best alternative is to just install a fresh install of Windows 95. It was a fun experiment after all!
did you check which partition is set active using the dos fdisk command ?
edit: FYI
These are the error messages normally found on an old MBR
- Invalid partition table
- Error loading operating system
- Missing operating system
and this is the error from the boot sector, PBR of a dos 5 fat formatted disk
- Non-System disk or disk error Replace and press any key when ready
Do not ask Why !
Reply 21 of 22, by Greger
weedeewee wrote on 2022-07-30, 20:06:
did you check which partition is set active using the dos fdisk command ? […]
edit: FYI
I will check tomorrow! But why isnt the computer simply booting the OS since I've typed in the right CHS parameters? I managed to start some games from the HDD while booted from the floppy disk. It's windows 95 that's on the computer, that's for sure.
Reply 22 of 22, by weedeewee
Greger wrote on 2022-07-30, 21:05:
also check which files are in the root directory of the drive, dir /A
I don't know why.
I guess, it seems like the MBR doesn't see the partition boot record. so maybe that is damaged, or the wrong partition is set active or ... .
Do not ask Why !
