"Some sort of IDeE card and a ide to sata with ssd?"
Well it’s all going to be limited to ISA bus speeds so anything using flash memory will hit that ISA speed restriction.[..]
Hi, good morning! That reminds me of something else.
The ISA-based IDE controllers are merely host adapters.
That means the IDE port was running at ISA bus speed.
So if you have an overclocked ISA bus (say 10 to 16MHz), the CF card will also communicate at a higher speed than normal! 🙂
Anyway, it just somes to mind.
Maybe that's useful to keep in mind if we continue to experiment with all sorts of IDE controllers.
The PCI controllers arw decoupled from ISA speed, of course.
But if we overclock the PCI bus or VLB bus (Intel 486DX50 system), similar things may happen.
Depending on the type of IDE controller. If it's too intelligent/advanced,
it may maintain normal IDE I/O timings no matter what.
PS: Caching IDE controllers may be useful, still.
They won't increase performance for CF cards, though. Troughput, I mean.
Access time might be a little bit faster, though.
These cards had 80186 "CPUs" often (which rather were early SoCs or MCUs) that run complex caching algorithms.
