First post, by brian105
- Member
Hey, everyone. I've been attempting to make this 7950GT work properly under 98SE for some time now with no success. It's a Foxconn PCI-e model with 512mb VRAM and it works just fine under Windows XP. To begin with configuration, I downloaded the unofficial 82.69 MDGX drivers which claim they have the 7950GT PCI ID in the .inf, but for some reason the installer did not detect the card and I had to install the driver manually with device manager. After rebooting, Windows no longer boots in normal mode and gives the error "While initializing device CONFIGMG: Windows protection error. You need to restart your computer."
I can boot in safe mode, but that's obviously not of much help. I attempted to install PTCHNVSZ (Nvidia VRAM patch from rloew) with the Nvidia driver patch, which patches NVCORE.VXD. Same error after a restart. I also tried the option ROM patch (patchopt.exe) which did not help either.
Just to make sure that this wasn't an issue of RAM, I installed patchmem to recognize more than 1GB RAM, and 98SE does properly recognize 3GB, though nothing on the GPU front changes.
Full system specs:
Asus M2V MX-SE (Via K8T890, chipset drivers installed)
4GB DDR2 800
Athlon 64 X2 6000+
Foxconn 7950GT PCI-e 512mb
Creative Sound Blaster Audigy 2 ZS
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
