First post, by buckeye
- Oldbie
Starting a new XP build and wanting to install on a 512GB sata ssd also new. Googling this is driving me mad since
there doesn't appear to be a general consensus on how to get this done.
Phil's videos involve using easy2boot with a thumb drive which seems like a lot of prep work involved.
One method offered was hook the drive up to a win10 system and align it properly and prepare it in
other ways I'm not familiar with using the command line. Once done you hook it up to the XP system
and away you go.
Still others insist that modern ssd's will work "out of the box" which would be ideal for me but sounds too
good to be true. Can anyone shed some light on this please?
Intel D865GL Pentium 4 2.4ghz. 512MB DDR 400 Geforce2 GTS 64MB SB Audigy 500W 98SE
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
