First post, by mikeyp
I have built 5 of these lovely ethernet cards for my XT and plan to sell 4 once they're working. I have run into an issue however where none will initialise properly. As you will see from the images below, all claim to have programmed correctly, but all present the identical issue of not initialising and reporting their mac address.
Am I being thick and doing something wrong here?
I have checked every pin for shorts and find it hard to believe I have made the same mistake on every card causing an identical issue. Surely it's software?
For reference, this is the card I have built:
https://github.com/skiselev/isa8_eth/tree/mai … software/driver
and this is the driver I'm using:
https://forum.vcfed.org/index.php?threads/ne2 … it-slots.41507/
Programming the 5 cards:
2 example images of the issue on different cards and versions of DOS:
