First post, by SamBushman
I'm looking to put together a 1-slot Magma PCMCIA-to-PCI setup. I've sourced the chassis, PCMCIA card, and the cable to connect them. From what I've read with the manual PDF, OSX support should be plug-and-play. However, WinXP support requires the Driver CD. Using the Wayback machine I can find an old download link, but it doesn't appear the driver archive itself was preserved 🙁
My Google-fu has failed me. Does anyone have the drivers hanging around? Thanks for any time and consideration.
Reply 2 of 3, by SamBushman
Holy moley! I actually found a good link!
I've attached the XP drivers, Redhat drivers, and the 1-slot manual
    1slot_manual.pdf
    1.31 MiB
    49 downloads
    linux.tar
    320 KiB
    30 downloads
    Windows Cardbus Drivers.zip
    3.23 MiB
    75 downloads
Reply 3 of 3, by lolo799
I was searching through archive.org at the same time, couldn't find my copy of the drivers...
The 10/19/2006 update which is not the one linked from https://web.archive.org/web/20111012112249/ht … dbus_driver.asp
Direct link:
https://web.archive.org/web/20070207142035/ht … dbusDrivers.zip
Windows98SE and upwards are supported by the drivers.
