First post, by gilly76
All,
Just picked up a gateway 2000 Family PC (Pentium 75) locally ($25, 🤣). The HDDs were both clicking when testing, so I decided to do the CF to IDE HDD (which worked fine on my Toshiba 440CDT laptop). I formatted one card to 2GB and installed MSDos and Win3.11 and everything is working fine. I wanted to have a second CF card with Win95 on it.
The issue is that the Gateway will only partition the drives to 504mb, nothing higher. For DOS, I set it up on the Toshiba and just moved the card over. For Win95, I tried fully installing it on the Toshiba (Disk I/O error) and then installing up to the "restart to finish" part. I also tried partitioning the CF at 32 gb, 16gb, and 8gb and none seem to work (using OCR2.5, which should support up to 32 gb).
Any ideas on what I can do to get Win95 to work with larger than 2GB (or 504 mb)? I used IDEINFO to make sure the Bios settings were right on the Gateway (BIS 1.00.11.BSOT).
Perhaps I should just keep MSDOS and WFW3.11 on it since i'm really looking to just play older DOS games and Win95 isn't really needed (just a fun to have at this point).
