First post, by kawe-dus
Hi,
Yesterday i want to use one of my old 486 Systems. unfortunately i recorgnized an bad smell.
On the PCB of my conner CFA340A Drive seems an tantalum resistor burned.
Because of the burning i cannot read the specification on the resistor.
Does someone have the same drive and can tell me which one i need ?
1.52 MiB
1.54 MiB
Reply 1 of 4, by weedeewee
FYI, a tantalum is a capacitor, most of the time those yellow/orangi ones, like the one marked 4µ7 35V ... not a resistor.
I still have a few conner drives, maybe I have the same one as you, I'll have a look and get back to you if something turns up.
edit: a quick look around didn't give me the same drive as yours, but a cp30174 does seem to have a similar capacitor to your drive.
The markings on it are A6µS, which I'm guessing means 6µF 10V .
Do not ask Why !
Reply 2 of 4, by kawe-dus
weedeewee wrote on 2022-10-15, 10:09:
FYI, a tantalum is a capacitor, most of the time those yellow/orangi ones, like the one marked 4µ7 35V ... not a resistor. […]
Hi,
Stupid me, you are absolutly right 😀
Thank you for your help. I will try an 6µF 10V capacitor.
Hopefully that my drive will come to live again 😀
Reply 3 of 4, by majestyk
That´s strange, there´s no E-series that contains the value 6.0
https://www.eevblog.com/forum/beginners/commo … pacitor-values/
and I have never seen a 6.0µF (tantalum) capacitor.
Just wondering if there´s another code applying here?
Reply 4 of 4, by weedeewee
majestyk wrote on 2022-10-15, 18:44:
That´s strange, there´s no E-series that contains the value 6.0 […]
You are right. lousy guess of mine.
Found a picture of the pcb using google and while fuzzy, it looks like it indicates 1-35. So 1µF 35V .
edit, and offcourse the resizing algo makes it a bit more fuzzy.
https://imgur.com/a/5EUOndj
    116.55 KiB
    CFA340A pcb
Do not ask Why !
