First post, by derpmochump
It doesn't have the FSB boot strap with official bios so bad to overclock locked cpus and northbridge gets hot af.
I need the bios that will give that option so i can lower it for fsb overclocking.
I forget the name of it though.
Anyonoe know and can help please?
MSI MS-6734 KM3M mobo / Athlon XP 3000+ /512mb ddr1 ram
Voodoo 3 3000 PCI @185mhz / Aureal vortex 2 (dell oem)
3dfx ref. drivers win98se and dual boot with winXP-32 bit running amigasport 3.0 3dfx drivers oc'd with koolsmokey's V.Control in XP
Reply 1 of 2, by derpmochump
Reply 2 of 2, by Horun
I do not know the bios mod name for the FSB thing, and at one time had a P4P800 and used a SLIC bios mod but that was all....
IIRC you could not unlock the multiplier on the P4P800. Maybe search thru www.bios-mod.com and see what you can find (I found nothing good)....
