Reply 40 of 43, by nathanieltolbert
Sphere478 wrote on 2023-05-29, 04:40:Any thought as to wether there is a jumper on this motherboard for putting the onboard cpu into flt? So as to allow the socketed cpu to function?
I fiddled around with the different jumpers that say factory set do not use, and all I was able to do was make the board non-bootable. I worked on it for a while but I never found a jumper that didn't have a function labelled that disabled the onboard CPU. I wish I knew more about this tech, but this is only my 3rd 386 motherboard I have used behind a Packard Bell PB 500SX, and a Tandy 2500SX/33. I am glad you got it figured out, though.
