First post, by andre_6
Hello everyone,
Last year I got an ATI HD 2600 XT AGP for my Windows XP (32 bit) build as I was advised it would probably be the most powerful I could find for that OS, with AGP interface through my Asus K8V-X board. I remember that even at the time I had trouble installing it, as Windows XP always took the drivers as unsigned so Catalyst setup would always skip over the drivers, reporting it in the log.
I ended up having to do it through Device Manager and pointing Windows to the .inf file, in this case CX171026.inf. The drivers package I used was "14-4-xp32-64-dd-ccc-pack1", the only drivers I could find that would work in XP, albeit with these issues.
I used the PC normally, and now a year later I was using it with some different games I hadn't played before, and I immediately noticed small graphical aspects that I attributed to drivers. I remembered my previous pain with them, still I tried again to find fully compatible ones, as in installing normally through Catalyst setup. I had no such luck again, as all of them abort the installation even through .inf pointing in Device Manager, stating they "couldn't find the necessary file", not specifying anything else.
I tried then to at least return to the previous drivers I had installed, and now I can't even reinstall them through .inf pointing as before, as it keeps asking for ATIICDXX.dat, which I only found as ATIICDXX.msi. If I try to run the .msi one it states it's not a Windows Installer. Before that it also asked for ATI2EREC.dll, which I could download separately and place in the System32 folder, but the ATIICDXX.dat just won't let me go through. So now I'm at a loss with all this.
1. Does anyone know of fully working signed drivers for Win XP 32bit for this card? Maybe even a CD image somewhere?
2. If not, could you at least point me out to some high end AGP cards for Windows XP 32 bit that is fully working in this OS? I'll just get another card if it comes to that.
3. My plan was to solve this graphic card issue in order to then upgrade my AMD Sempron 2800+ to a 3700+ Athlon 64. As my board is an Asus K8V-X, according to CPU upgrade it's compatible right?
As always, thanks in advance for all your help and replies
