First post, by Senior System Engine
- Newbie
So I just bought a nice IBM PC350 486DX4-100MHz. It has a Sony Magneto-Optical drive in it. I've been around the block a few times and can't believe I've never even heard of this technology, never mind seeing or owning one. Anyway, the hard drive was yanked from the machine so I've installed MS-DOS 6.22 and WFW 3.11. The Drive is connected to an Adaptec SCSI board. I have two 1.3GB cassettes for it. I've found the correct drivers and set them up in CONFIG.SYS and they load fine. I can't get the drive to be readable (i.e. format it or copy files to it).
Here's a summary of the Specs:
- Adaptec ISA SCSI interface Card (AIC-6360 Family/AHA-1522A)
- Sony Magneto-Optical Disk Drive (SMO-F531) 1.3GB @ 1024 Bytes/Sector
SCSI ID# - 5
Port – 340h
CONFIG.SYS:
BUFFERS=30
FILES=30
DEVICE=ASPI2DOS.SYS /D
DEVICE=ASPIDISK.SYS /D
When I run AFDISK.EXE, I get this error:
download/file.php?mode=view&id=149668
When I run SCSIFMT.EXE, I get this error:
download/file.php?mode=view&id=149669
Can anyone help me troubleshoot these cryptic errors or give me any help on how to proceed?
Thanks,
Scott
