First post, by joemorgan
Hi guys, I'm new in town.
I usually read without interacting but a question has arisen. This is the moment... . 😀
A few years ago I formatted an IBM 5162 hard drive using a BIOS routine call from the computer's ROM BASIC.
I saw it done in a YT video but they have deleted it.
I found it easier than using debug.exe or any other software.
Does anyone know how and what the routine was executed from the IBM BIOS BASIC (Cassette BASIC)? Honestly, I have forgotten.
Thanks for all beforehand.
Reply 1 of 5, by Ryccardo
Never tried anything mentioned in this topic, but if I read the manual correctly, if you want to run an option rom at D800 from address 5:
10 def seg=&hd800
20 def usr0=5
30 print usr0(0) < any number as argument
run
Good luck!
Reply 2 of 5, by maxtherabbit
Ryccardo wrote on 2022-11-16, 21:39:
Never tried anything mentioned in this topic, but if I read the manual correctly, if you want to run an option rom at D800 from […]
10 def seg=&hd800
20 def usr0=5
run
Good luck!
the default location for XT disk ROMs was C800
Reply 3 of 5, by joemorgan
10 def seg=&hd800
20 def usr0=5
run
Good luck!
Thank you pal !
Reply 4 of 5, by joemorgan
maxtherabbit wrote on 2022-11-16, 21:44:
10 def seg=&hd800
20 def usr0=5
run
Good luck!
Indeed, I think it is C800
Thanks!
Reply 5 of 5, by Horun
Back in the day used Debug to enter the Controller BIOS, like G=C800:5....
