First post, by SoftMachine
Hey, first post on here. I'd like to start making my own 80 wire 30 AWG IDE cables as I go through a lot of them, but in my search for components I've found some connectors that are labeled as being meant for 80 wire ribbon cable and this is a bit confusing to me. Is there a difference between the normal keyed 40 pin IDC connector and a connector I'd use to create an 80 conductor IDE cable?
