First post, by Excelsior
Hello,
Can you recommend a PCI controller card with SATA connectors?
I would like to use it with an older Pentium 3 computer because I don't have any functional PATA HDDs.
In such a case would I have any problems concerning compatibility since this is an older 815EP chipset motherboard?
Thanks in advance!
Reply 1 of 4, by brian105
Promise SATA cards are pretty good for compatibility with older machines.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 2 of 4, by douglar
brian105 wrote on 2022-12-07, 09:36:
Any of the TX2 models should be good.
You want to get a controller that has a BIOS EEPROM on it for booting. The cheaper ones without the BIOS usually cannot be used to boot unless you can find another way to jam that option rom into your system.
Highlighted chips is the EEPROM
712.16 KiB
Reply 4 of 4, by Tiido
I have good results with SIL3112/3512 and SIL3114/3514 cards, although BIOS on them must be right version for 9x driver to work right and it can take some effort to reach that point.
