First post, by jcdevel
Dear Vogons members and enthusiast,
This is my first post in the forum. After many days of reading and research (during which I have learnt a lot), I have faced a bricked wall and I need help from experts.
I have an old Toshiba T1910CS laptop, originally with DOS/Win3.x, then I upgraded it to Windows 95 SR2.5. I would like to expand the storage capacity by using a CF card in the PCMCIA socket, so I bought one of these cheap adapters from Aliexpress and a 512 MB Compact Flash. I can read/write the CF from my everyday laptop using a USB-CF reader. The partition is FAT16, to maximize compatibility with DOS/Win3.x/Win95.
From what I have read, Win95 should be able to access the CF almost automatically. However, this is not my case. This is what I have achieved so far:
  1. The PCMCIA socket drivers are installed and work correctly. I am using the default PCMCIA PCIC compatible controller (I do not know the specific hardware, but the generic driver seems to work fine)
  2. When the card is inserted, Win95 detects it correctly. A pop-up with the CF brand and model shows up (TRANSCEND-TS512MCF80).
  3. Next, the driver installation wizard starts, recommending the standard IDE/ESDI disk controller. I follow instructions and the wizard finishes successfully. A beep sound is generated.
  4. The new IDE/ESDI controller shows up in the Device Manager, next to the internal HDD driver. Resources allocated (I/O ports and IRQ) correspond to secondary IDE (0x170-0x177, IRQ 15). No conflicts.
  5. However, no driver letter is assigned to the CF and no drive unit is shown in My PC.
  6. If I check the Removable tick box in the Generic IDE Disk configuration, then the unit shows up, but when I try to access, the computer freezes for a few seconds, then it says that the unit cannot be accessed.
A couple of things I have done to verify that the PCMCIA and the CF card are working fine:
  1. If I load APSoft ATAENAB (DOS Enabler for ATA Cards) from Config.sys, the CF is recognized, I/O port allocated is 0x150 (no IRQs needed), driver letter D: is assigned and shown in My PC and I can access the CF without problem. Windows 95 complains about real-mode drivers detected and potential loss of performance in compatibility mode, though.
  2. If I insert a network card in the PCMCIA socket (Buffalo LPC3-TX), after installing the drivers the card works flawlessly. I can even access Google from this 30 year-old laptop!!! 😀
This made me think that the root cause might be in the IDE/ESDI driver. There must be a difference between the ATA/IDE driver embedded in ATAENAB (which works) and the driver provided by Windows 95 (which fails), so I started to read about ATA protocol when I came across this post:
http://support.fccps.cz/download/adv/frr/cf.html
Apparently, these cheap CF-PCMCIA adapters are missing some signals in the wiring that prevents access to the CF card if DMA mode or ATA PIO modes above 2 are used. Could it be that Windows 95 IDE/ESDI driver is trying to access the CF in a different mode compared to ATAENAB? Can this be adjusted in the driver configuration? Or am I talking non-sense and the problem relies somewhere else?
Any help will be much appreciated. I am really lost and nearly to the point of giving up.
Thanks everyone in advance!
BR
Reply 2 of 3, by jcdevel
Should I try different CF brands/models then? The thing is that my CF works (ATAENAB proves so), so my gut feeling is telling me that something can be done at the software level to make it work under Windows 95, either adjusting some configuration setting or perhaps using a specific driver.
How can I know in Win95 what PIO mode is the IDE/ESDI driver using to access the CF? Or what resources has the PCMCIA driver (I/O, IRQs) allocated to the CF?
Reply 3 of 3, by douglar
If you have a CF handy, sure, why not try it. Probably isn't the issue, but if it's easy to try, it is a simple way to lop off some branches from the troubleshooting decision tree.
You could try running a info tool like speedsys, hwinfo, or norton to view the ATA info.
Windows 95 device manager properties for the device should show you the rest of the stuff.
I spent two years working with 486 PCMCIA laptops back in the mid '90's. My strongest recollection is that I didn't want to work with PCMCIA devices again. That early plug-n-play stuff could really take you down some dark, unlit streets, especially if it required vendor drivers to work.
