desperate for quality AT psu
First post, by zzzxtreme
hello guys. I've acquired a 286 and 386 PC. after connecting them to my Pentium1 PSU, they both boots up.
so today I bought another two AT psu, and both cannot be used.
years ago, I've tried a modern ATX PSU with ATX-to-AT cable, and it blew up in smoke.
These two vintage computers are my dream come true, but it is near impossible to get good quality AT PSU.
what are my choices?
Any help is greatly appreciated.
Reply 2 of 20, by Gmlb256
I didn't have any issue using an ATX-to-AT cable either, even mine has an adapter for -5V which is no longer available.
Reply 4 of 20, by Sphere478
Re: ATX to AT pico Adapter! + Fan Headers, -5v, and 3.3v (Released)
What about this? 😀
Turn atx into AT!
Sphere's PCB projects.
Reply 6 of 20, by zzzxtreme
ok guys. I've orderd the ATX-AT cable , and a modern quality ATX PSU.
When it arrives, I will connect them but won't switch on until I post photos first.
Now, can I re-use the original switch on the AT case ? The AT case switch is
Black-White
Brown Blue
the adapter cable has only Green and Black
Reply 7 of 20, by Sphere478
Yes, just use two of the plugs on the switch
by the way be sure to order the adapter that has the long wires for that switch I don’t know what they were thinking making an adapter That has short wires.
On the motherboard black to black
zzzxtreme wrote on 2023-01-06, 07:01:
Open source, order and build yourself
Jlcpcb
Reply 8 of 20, by drosse1meyer
zzzxtreme wrote on 2023-01-06, 10:50:
ok guys. I've orderd the ATX-AT cable , and a modern quality ATX PSU. When it arrives, I will connect them but won't switch on u […]
Black-White
Brown Blue
http://209.68.14.80/ref/power/sup/partsSwitch-c.html
or you can just short the green/white and use the switch on the back of the PSU
Reply 9 of 20, by zzzxtreme
drosse1meyer wrote on 2023-01-06, 13:35:
Black-White
Brown Blue
Thanks! Can you elaborate? The adapter cable has black and green only.
For the 4 cables on the switch, i just unplug and throw them away?
Reply 10 of 20, by drosse1meyer
zzzxtreme wrote on 2023-01-06, 14:45:
Black-White
Brown Blue
Yea i meant black/green sorry. Solder them together or use some sort of other method to keep them reliably shorted
However, since you have the AT switch already there, it would probably be best to at least try using two of the 4x leads instead, i am not sure it matters which pair you use for the adapter, but I guess i'd test the black/white first.
FYI you can test this without connecting the motherboard, just see if the PSU fan kicks on and you know it worked
Reply 11 of 20, by stef80
This is how connector should be pluged into the MBO (black wires in the middle):
979.18 KiB
And this is switch side:
723.55 KiB
Basically, you connect one half of the switch in any order. There are just 2 wires.
Just mesured lenght of the switch wires, it's 75cm (~30 in).
You dont have to plug into the motherbord to test if PSU starts.
Reply 13 of 20, by zzzxtreme
Hello guys it is me again. I’ve ordered an atx psu and atx-at cable. Not yet arrived
Today I saw a youtube video. A guy demonstrated that his 286 computer has a capacitor hooked up to -5v rail.
Does that mean those kinds of mobo cannot use ATX-AT cable that has no -5v supply?
Reply 14 of 20, by stef80
They can, you just cannot use some old sound cards that require -5V:
ISA Cards & Devices Requiring -5V
Since target platforms are 286 and 386, you might be affected.
You can also look into:
https://www.tindie.com/products/retrofletch/v … odern-psu-5v-m/
It was reviewed by Phil:
https://www.youtube.com/watch?v=y1-0giyLQIY
Reply 15 of 20, by Sphere478
The adapter I posted above deals with the -5v issue
Most motherboards will work without it. I believe it is some sound cards that really need it.
Reply 16 of 20, by lawyerpepper
I've been curious for a while if these are legit: https://www.amazon.com/ATHENA-SUPPLY-Athena-C … 43SQ/ref=sr_1_2
I haven't actually needed one, since my retro rig is a Compaq that takes a Compaq PSU, but apparently they are new-built PC AT PSUs.
Reply 17 of 20, by mscdex
lawyerpepper wrote on 2023-01-11, 01:18:
I purchased one of those a few years ago when it was at a slightly cheaper price and it has been working fine with my test bench PC.
Reply 19 of 20, by drosse1meyer
zzzxtreme wrote on 2023-01-13, 10:31:
Thanks all. New atx psu arrived. Both the 286 and 386 booted without explosion.
nice
