First post, by fastopen
Hi all,
does anyone know switch configuration in an old RAM memory ISA expansion card manufactured by NCR? It is an ISA 16bit card with a switch packet of 8 positions (in red)
329.39 KiB
230.93 KiB
385.75 KiB
Best regards,
Reply 3 of 4, by Predator99
This is a nice card that should fit in a 286. If you dont find a documentation you can try to follow this:
ISA XMS/EMS Memory Extension / Expansion cards: Now Running without Driver / Documentation :-)
Run testx.exe first and report the result in the linked thread.
Reply 4 of 4, by luckybob
it looks like NCR made that card. (at very least the ASIC) I would wager this card to be mostly universal and a google search for "isa memory card NCR 30-pin" would strike close to the target.
