First post, by dinamo
Hi Folks!
Last week I bought a D9820-60009 rev 0X-AA (from a Vectra VL400) motherboard with i815 chipset .
I would like to know if its AGP port is compatible with a Voodoo 3 2000. I know that this port is "universal" but im not really sure if both 1.5v and 3.3v are supported
Hope anyone of you guys could give me a hand with this
Thanks!
Reply 1 of 5, by Tetrium
That AGP port should be compatible with a Voodoo 3. I'd actually be surprised if it wasn't.
No idea how standard your motherboard is btw.
My retro rigs (old topic)
Report spammers here!
Reply 3 of 5, by Ryccardo
Tetrium wrote on 2023-01-16, 11:51:
It's very fine IBM compatible if you ignore the 50 pin bus connector + DC out for the optional 2x ISA card, the 5 pin data connector for the internal UPS option (the original power supply has a 3 pin connector for rectified mains in/out), the (by that time) nonstandard CD audio connector, the mysterious red power LED, the missing (nonstandard?) additional power socket, or the "drm" on the power supply (short pins 1 and 3 of its fan connector, which btw doesn't output power) 😁
Of course it's much nicer with the original case, which makes everything (except optical drives) line up neatly with the connectors, byt then you have a non-standard power supply, maybe some day I'll make a FTX adapter frame!
Easily the most satisfying PC I've ever owned (being my first personal one, bought in 2005 for 80 € at the electronics fair), only in 2017 I mamaged to get 2x256MB for it!
Reply 5 of 5, by Tetrium
dinamo wrote on 2023-01-17, 23:32:
Finally, the Voodoo3 worked flawlessly whith this motherboard! I'm very happy!
Nice, enjoy 😀
