First post, by GabrielKnight123
My corsair RM550X died and I have to replace it for my 486, it's being used with an adapter that has a 5 watt resistor on (from memory) the 3.3 volts but I'm not sure if all the new ATX power supplies are good for a 486 when it comes to watts on each rail for example would the Cooler Master MWE GOLD 550 V2 be good I've heard not to throw a high 800 watt psu at a 486 hence the lowish cooler master 550
