First post, by murrayman
I have a Packard Bell Multimedia SB610 and a Compaq Presario 5170 that I wanted to change out the PSU in each, just for sanity’s sake. But since mentioning it once in a separate thread, I’ve been alerted that some PSUs of the era may use standard AT plugs, but have proprietary wiring - so if I use an ATX-to-AT adapter with a new PSU, I might blow everything up.
What’s the most effective method of determining if a vintage AT PSU uses standard or proprietary pin out arrangements? I’ve tried looking for service documentation for each of these models online, and while I did find some for the Compaq, I didn’t find anything for either detailing the PSU or the pin arrangement on their respective motherboards. There are no indicators on the frame of the PSUs or the motherboards themselves either.
P3B-F 1.04, PIII 1k, 512MB PC133, GF DDR 32MB + DM3DII 12MB SLI, SB0100
P3B-F 1.03, PIII 700, 384MB PC100, V5 AGP, SB0160
CP 5170, PII 350, 256MB PC100, Rage LT 2MB, ESS 1869
PB M S610, PMMX 233, 128MB EDO66, DM3D 4MB, Aztech
