First post, by guitarbloke
I've just acquired a Win98 (not SE) PC. Trying to run a few DOS games on it but I'm having issues after editing the autoexec.bat and config.sys.
I press F8 during the boot sequence and choose Command Prompt Only and the system just hangs there. I don't get the command prompt, just a flashing line
The autoexec looks like this:
set prompt=$p$g
set path=c:\windows
set blaster=A220 I5 D1 H5 P330
c:\cdrom\mscdex.exe /E:MSCD001 - (I've ensured that the mscdex.exe file is in the c:\cdrom directory)
The config.sys looks like this since I REM'd out a few lines trying to isolate the problem:
REM device=c:\windows\himem.sys
REM DOS=high,umb
REM device=c:\windows\EMM386.exe noems
device=c:\cdrom\oakcdrom.sys /e:MSC001 (oakcdrom.sys is a generic cdrom driver that works with most drives)
Any ideas where I've gone wrong? 🙁
Reply 1 of 9, by Gmlb256
Hello, I have some things to say about this:
  • PROMPT is not an environment variable. Should be just PROMT $P$G without the SET command.
  • Which sound card are you using for initialization? SB16 or AWE?
  • PATH environment variable doesn't have C:\WINDOWS\COMMAND directory included which has some essential DOS commands. Should be SET PATH=C:\WINDOWS;C:\WINDOWS\COMMAND and it is the default one.
  • MSCDEX already comes with an installation on Windows 98 and it is located in C:\WINDOWS\COMMAND, use that instead which is the latest version.
Reply 2 of 9, by guitarbloke
Gmlb256 wrote on 2023-01-22, 19:07:
Hello, I have some things to say about this: […]
Thanks @Gmlb256!
I'll make the changes you suggest and report back 😀
The soundcard I believe is sb16 compatible - I'll need to check and confirm exactly what card it is though. Am I using the wrong command line?
It's been so long since I was completely familiar with autoexec and config.sys that I'm probably getting this all wrong and using half-remembered commands strings from my childhood!
Reply 3 of 9, by Gmlb256
guitarbloke wrote on 2023-01-22, 22:38:
No, I just saw the BLASTER environment variable but no program to initialize the sound card in DOS as I don't know which one exactly.
Reply 4 of 9, by guitarbloke
Gmlb256 wrote on 2023-01-22, 23:06:
I think I've narrowed it down to the cd driver - If I REM that line out and reboot, I get a working command prompt. But As soon as I add it back in, it fails to load the prompt.
I can't see where I'm going wrong though - this is how is currently is (I've removed the blaster variables until I know the driver details/location).
Autoexec:
prompt $p$g
set path=c:\windows;c:\windows\command
REM c:\windows\command\MSCDEX.EXE /D:MSCD001
Config.sys
dos=high,umb
device=c:\windows\emm386.exe noems
REM device=c:\cdrom\oakcdrom.sys /D:MSCD001
All works perfectly until I add those cd driver lines back in.
Reply 5 of 9, by Gmlb256
Strange, try with GSCDROM.SYS which is nearly the same thing as OAKCDROM.SYS. If that still doesn't work, then with VIDE-CDD.SYS but that one is slightly less compatible.
Reply 6 of 9, by Horun
Do you have a cdrom in the system ? Personally have never had an issue with oakcdrom.sys (specially d91 or D11 both) from 1995...
How about telling us a bit more about your system ? What motherboard, what CDROM, etc....
Reply 7 of 9, by guitarbloke
Horun wrote on 2023-01-23, 01:53:
Hi @Horun,
Here's what I can tell you about the system -
Windows 98 (not SE)
Pentium II 266
Motherboard is a Microstar MS-6118
64MB RAM
10GB HDD
Floppy drive
Geforce2 MX 32MB
The drive is an LG DVD/CD-RW writer
I've got a PCI USB expansion card on the way which will help me with transferring files over (I don't have any floppies at the moment and it's a pain having to burn a CD everytime I want to transfer a file to the machine)
I haven't had a look at the soundcard yet physically, but Device Manager reports that it's a Yamaha OPL3-Sax (sound works works perfectly in Windows).
Reply 8 of 9, by Gmlb256
guitarbloke wrote on 2023-01-23, 10:09:
This means that the sound card definitely isn't SB16 compatible, it is a Yamaha YMF-71x based ISA sound card which is compatible with SBPro2 and WSS (Windows Sound System) for DOS programs.
Reply 9 of 9, by guitarbloke
Gmlb256 wrote on 2023-01-23, 13:32:
Aaaah ok! So I'll need to change those lines as well in that case, thanks!
