First post, by pentiumspeed
The important pins that controls the SRAM ICs also four 4 pins for ground and VCC remains the same but checking the 3 different makers of 128k x 8 sram chips has different data lines numbering but all data pins are physically same for 32 pin SOJ IC package.
What gives?
http://www.datasheet.jp/pdf/439678/MCM6726DWJ12.html
http://datasheet.eeworld.com.cn/view/39427505.html
https://www.issi.com/WW/pdf/63LV1024_L.pdf
Cheers,
Great Northern aka Canada.
Reply 1 of 2, by weedeewee
it doesn't matter which sdram connector data bit goes to which memory chip data bit.
Do not ask Why !
Reply 2 of 2, by pentiumspeed
Yeah, I thought that same thing. I learned to read schematics and data sheet for decades till now.
Was not sure.
Cheers,
