First post, by Syntho
Hey guys, I've got an AMD 25mhz 386 integrated. I see a couple chips on it: an AMI BIOS chip and a keyboard chip. Not sure there are any other chips but will take a closer look. This is what I get when booting:
Top:
ROM BIOS American Megatrends Inc
A423073191
Bottom:
30-0501-D31169-00001111-05091-ITOPSX-8
I don't know which brand/model this is and I can't find any BIOS info online. Can someone identify this make/model, and most importantly: do you think I should pull those Keyboard and Bios EEPROMs and make copies of them while they still work?
Reply 1 of 7, by fool
Do you have pictures?
Here is a great thread to record BIOS file if you decide to dump BIOS EPROM.
80386 BIOS image collection
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 2 of 7, by Syntho
There's a sticker on it that says "MSI: 878945"
I'll need to tear it down to take pics.
I have the bios and keyboard chip out. Here's what they say underneath:
S 27C512 -12 FA […]
S 27C512
-12 FA
230C505
9114WG
What kind of chip is this? I'll need to select in my software before copying. I don't see an actual brand on the chip besides that big S, but I do see an option for a generic "27C512", and also another option under the "??? " brand that says "27C512-12.7V".
The keyboard chip is an EEPROM since there is no window. It says:
123101
M5L8042-189P
It has the Mitsubishi logo too so the brand is obvious. I don't see an option for that particular chip in my software though.
Reply 3 of 7, by fool
Syntho wrote on 2023-02-12, 08:59:
S 27C512 -12 FA […]
S 27C512
-12 FA
230C505
9114WG
That is Philips/Signetics 27C512. "12.7V" stands for programming voltage but you don't need to mind about that.
You can use any 27C512 DIP28 option for reading. To verify dump correctness just take a few dumps and check there are no differences.
http://matthieu.benoit.free.fr/cross/data_she … 27C512-20FA.pdf
The keyboard chip is an EEPROM since there is no window. It says: […]
123101
M5L8042-189P
That is more like microcontroller with internal ROM that works as keyboard controller. You don't need to dump that one.
Datasheet here https://datasheetspdf.com/pdf-file/1147941/Mi … /M5L8042-XXXP/1
Reply 4 of 7, by Syntho
Luckily I have a video from months ago of it, and some pics. Here they are:
https://youtu.be/TzQQ2m1nEV8
Reply 6 of 7, by Syntho
fool wrote on 2023-02-12, 09:32:
Very good condition!
Is that Varta battery original?
The battery is no longer with us. R.I.P.. I took these pics months ago to remember how everything was plugged in because I soldered in a new battery. It now has a cellphone battery pack 😀
See the attached for the BIOS. I verified it 3 times. Seems to be good.
Do you think it's possible to come up with an identity for the board?
    amd38625.BIN.zip
    38 KiB
    35 downloads
Reply 7 of 7, by weedeewee
Any chance of getting photos of ONLY the mainboard and nothing but the mainboard, front & back.
from the bios code, I'm guessing it's an old MSI board, though not directly listed on theretroweb.
Do not ask Why !
