Thanks everyone for the links 😁 (if You can then add more )
I take everything 286/386/486 and early Pentium schematics . It would be good if moderator creates a topic with "schematics" .
I also have a PDF with the description of the chipsets . I can add to the forum.
Too bad the producers don't publish old schematics .The technique is too old, so no one will copy it today 😀 .
Example of a board for which the chipset description cannot be found . I used someone's link from this forum but I have the same motherboard Re: Try to fix old 786 ACIO VESA 386/486 Motherboard
USAi SC-9204-A chipset .
Next example , ALI chipset description cannot be found ALI 1429 A1 and ALI M1431 A2 .
Here is an interesting link to the chipset datascheet http://ftpmirror.your.org/pub/misc/bitsavers/components/
Horun , do You have these documentation on an ftp site or something similar ? I take everything .
