majestyk wrote on 2023-03-14, 07:25:All GA-586DX with the two golden heatsinks at the CPU sockets DO suppurt dual voltage. I haven´s seen one without so far. There´ […]
All GA-586DX with the two golden heatsinks at the CPU sockets DO suppurt dual voltage. I haven´s seen one without so far. There´s only one (non-5V) core voltage available - 2.8 / 2.9V for Pentium MMX (or single AMD CPUs).
There´s also a seperate 3.3V regulator for I/O etc.
Due to severe(!) BIOS limitations many "modern" PCI cards don´t work properly on the DX2.
Please also note that the GA-586DX is quite finicky in general. You will notice that when you install any OS like NT, 2K or Linux. As soon as you have SCSI, Video, Sound, Network (let alone USB) the IRQ hell will start.
And this was the outcome (again, bios is crippled, wish I know how to fix it):
Your computer's system firmware does not include enough information to properly configure and use this device. To use this device, contact your computer manufacturer to obtain firmware or Bios update. (Code 35)
This error message is displayed when a device does not have an entry in the BIOS MultiProcessor Specification (MPS) table. You can only see this error message on MPS-capable systems. This behavior usually indicates a BIOS bug. This is particularly prevalent on MPS systems with multiple root PCI buses.
• Obtain a firmware or BIOS update. If no update is available, you cannot use the device.
• If the BIOS has an option to switch between MPS 1.1 and MPS 1.4, you can try switching because a different table is loaded. You usually want the system set to MPS 1.4.
Problem is that I can't switch from one MPS to another in the bios anyway.
The only settng I can change is "MPS 1.4 for single CPU = Disable/Enable".
