First post, by criz_me
Hi there,
I recently purchased a practically new P2B-B which ran quite nicely for a few days in my Tualatin / Voodoo 5 retro gaming rig. After opening and closed the case I noticed the PC has frozen (unresponsive to any input on windows desktop), so power cycled it. It is not showing any video signal since.
I have tried hundreds of things already to isolate the issue, which I will list below. Also, I have searched on here and elsewhere for potential causes. Nothing has revived the board for me so far. I do not want to give up on this nice piece of hardware, so I would highly appreciate any help.
Setup:
- Asus P2B-B rev 1.02 - Bios 1014 beta (also tested v1011)
- SL3JM, SL6BY on MSI MS6905, SL3S9, SL5XQ on Abit Slotket III (*)
- Voodoo 3 PCI, Voodoo 5 5500, Diamond Viper V550 (*)
- SM564168574N03R, Micron MT16LSDT3264AG-13EE1 (*)
(*) of the listed working and tested on other boards, GIGABYTE GA 6BA Rec. 2.9 and Ford Lian BX-6AV2.
Things I have tried:
- Purchased another BIOS chip and flashed externally - no change
- Post code card is also of no help, at least to me. "00" does not seem to resolve to anything with Award
- Checked monitor on another mainboard / gpu - works
- All contacts are clean, no dust no broken conductors...
- Cleared BIOS by shorting corresponding jumpers
- Tested ATX and AT power supply which both work on other mainboards
- Plugged RAM into other sockets - no change
- New BIOS battery - no change
- PC speaker beeps long repeatedly, when no RAM is present - so that is something...
- Other things I may have forgotten.
Thanks again
Christian
    696.78 KiB
    1.05 MiB
    740.63 KiB
    747.42 KiB
    986.34 KiB
Reply 1 of 29, by Horun
Does it boot with a standard P2, like a 350 ? just curious...
Reply 2 of 29, by rasz_pl
criz_me wrote on 2023-02-27, 22:21:
I can see C1 on the picture?
just 00 would mean CPU is not running at all. I would start with measuring 3.3V rail and CPU vCore.
and that would suggest cpu is running
Reply 3 of 29, by criz_me
@Horun - I do not have a PII at hand, sorry
@rasz_pl - I think the tester indicates the current code on the left display and the previous code on the right. Not 100% sure though.
How / where would I measure 3.3V rail and CPU vCore? Not exactly an electrical engineer here 🙁
Reply 4 of 29, by criz_me
Not really sure what I am doing - but here is what these two measure.
    416.07 KiB
    247.39 KiB
Reply 5 of 29, by ciornyi
hello mate ,
C1 code is memory related code so id check another stick of memory.
And for sure id finger check if anything getting hot.
btw why do you using AT psu ?
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3_900/256mb/SB live/3dfx V3
Win Me: Athlon 1700+/512mb/Audigy2/Geforce 3Ti200
Win XP: E8600/4096mb/SB X-fi/HD6850
Reply 6 of 29, by criz_me
Hi ciornyi, yep I tested two different sticks, SM564168574N03R and Micron MT16LSDT3264AG-13EE1. The ladder was the one the system was running fine with, for a few days.
And yes, the headsink is getting warm / hot.
Mainly for testing purpose, to eliminate the ATX PSU as a possible cause.
Cheers
Christian
Reply 7 of 29, by criz_me
With the GPU inserted the post code card indicates "25" and "0C". Without it it indicates "50" and "C5", sometimes in reverse order. I find it hard to make any sense from it https://www.hzdr.de/FWR/VB/BIOS/awpost.htm
Reply 8 of 29, by rasz_pl
criz_me wrote on 2023-02-28, 19:49:
C1 shows up later, C0 is the first code possible, so CPU is running, but stopping at C1
criz_me wrote on 2023-02-28, 21:26:
memory problems, reseated? memory and now it progresses further
http://mrbios.com/techsupport/award/postcodes.htm scroll down to Late Award BIOS (4-5x PnP)
all of those codes still indicate ram
measure on all the coils on the motherboard - three wire wound around yellow/blue rings on right side of the cpu
try switching Vcore test/normal and Vio jumpers
maybe memory supply is weak and results in erratic memory behavior
Reply 9 of 29, by shevalier
see pic 😀
    324.85 KiB
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 10 of 29, by criz_me
@shevalier CPU core = 1.832v, 3.3v rail = 3.500v
@rasz_pl
Coils in picture above:
- Bottom: 5.091v
- Top left: 0.459v
- Right: 0,002v
Yes reseated, both RAM sticks, multiple times, different slots. They both work on the Gigabyte and Ford Lian MB.
Appreciate your help guys!
Christian
Reply 13 of 29, by shevalier
watson wrote on 2023-03-01, 23:07:
Which CPU was installed when you measured the core voltage?
I support this question.
For Tualatin - to many, for "mendocino_like" - to small.
I would check the connections between HIP and slot1 (on the cpu/adapter side) for VID`s signal.
Page 9
https://pdf1.alldatasheet.com/datasheet-pdf/v … HIP6019BCB.html
Reply 14 of 29, by rasz_pl
as watson says
none of those are too close to "CPU core = 1.832v".
>VIO set to 3.66v: Post card indicates "25" and "C5" constantly on every start. No further change
0C is further in the post process than C5
>- Bottom: 5.091v
>- Top left: 0.459v
>- Right: 0,002v
did you measure that with no cpu? 😀 right one is cpu voltage, top left is ram supply
Reply 15 of 29, by shevalier
rasz_pl wrote on 2023-03-02, 05:21:
For AT-motherboard (asus did this and for ATX) this DC/DC from 5v to 3.3V.
Its system 3.3V rail for RAM, chipset, AGP and PCI
Reply 16 of 29, by criz_me
@watson:
-> SL5XQ that came with the Slotket III
Could you try the SL3JM and verify that you are getting close to 2.05 V?
-> 2.147v
SL3S9 -> 1.729v
@shevalier:
Voltages between HIP VCC (pin 28) and VID of the Slotket, see IMG_488. Also measured GND (pin17) and VID see IMG_489. I am not sure if I am measuring the right pin on the Slotket. It is the small VRM on IMG_0484.jpg.
@rasz_pl:
>> That could be, yes, sorry. See IMG_490, I think the coil is pulling voltage down to exaclty 1.800v.
    643.65 KiB
    762.43 KiB
    646.79 KiB
Reply 17 of 29, by rasz_pl
criz_me wrote on 2023-03-02, 10:39:
you arent 😀 afaik this small chip is for VTT or termination, has nothing to do with Vcore
Cpu and ram are getting good power, at least voltage vise. Since it was working with Tualatin VTT might be suspect, Asus had problems with good VTT in early boards, they called it "photoshop bug" or something. googling .. oh there it is https://www.eecis.udel.edu/~portnoi/asusreworkguide.html
also Fixing ASUS P2B freezes on memtest86+ modulo 20 test
Might need a scope to verify further.
You could try flashing another bios chip in the meantime just to be on the safe side.
Reply 19 of 29, by shevalier
rasz_pl wrote on 2023-03-02, 11:41:
VTT reg at pic.
I don't think, that is problem to boot
    130.27 KiB
