First post, by Jennifer.Diamonds
Trying to use my ram in Dual Channel mode
Motherboard: GA-8IPE1000-G Rev.4 (Installed latest bios, no options to enable/disable dual channel in bios)
CPU: Northwood P4 3.2ghz (hyperthreading disabled in bios)
Ram: x2 Corsair Twinx 512mb, x2 Nanya 256mb (Tested separately and together. Used R.loew's Mempatch with the 1gb/1.5gb tests)
OS: Win98SE (Tried with/without the unofficial sp3 and other update packs but they tend to break more things than they fix in my case)
My post screen states "Memory runs at Dual Channel"
CPUz states single mode.
Included CPUz log with both sets of RAM installed (As stated, I've tested them separately and the results are the same)
Is there something obvious that I'm overlooking? Like maybe win98 simply doesn't support dual channel?
Single channel mode is "fast enough," but I'd like to see things work as intended rather than settling.
