First post, by Yoghoo
Maybe a strange question but I have a Slot 1 board with a Pentium III CPU which I don't use and the CPU would be perfect for a Socket 370 motherboard I have. It would be the opposite of a slotket so to say.
So the question is if this possible with some desoldering or would it be a mission impossible?
Reply 1 of 9, by Big Pink
The cartridges for Coppermine PIIIs are basically like a slocket without a ZIF socket, it just exposes the soldered-on CPU pins in the SC242 form factor. Once you've desoldered it, you'd need to mount the BGA onto an appropriate adapter for fitting in a PGA370 socket. Which all sounds like a fiddly nightmare compared to just buying the Socket 370 version.
I thought IBM was born with the world
Reply 3 of 9, by Warlord
improbable
Reply 4 of 9, by smtkr
Just sell the Slot 1 and buy a Socket 370. It's probably a profitable trade and you don't have to destroy a CPU. I've seen someone manually solder a BGA CPU. In addition to all the extra equipment you'd need, it looks incredibly frustrating.
Reply 5 of 9, by Repo Man11
The SECC package was used to integrate the level 2 memory cache with the CPU without it being part of the CPU itself, so if it were possible to remove the CPU from the SECC package and use it on a Socket 370 motherboard it would have no L2 cache. Here's a review of the Celeron 366 that goes into detail: https://www.anandtech.com/show/219
Reply 6 of 9, by Ozzuneoj
Repo Man11 wrote on 2023-03-22, 03:14:
This was the first thing that popped into my mind when reading the thread title.
Slot 1 CPUs are more than just a Slocket with a CPU on them. The other chips on the CPU's PCB are cache.
Also, if it's a high clocked 100Mhz FSB CPU it is probably worth enough to justify selling it and buying whatever you need for the other build.
Reply 7 of 9, by TrashPanda
Didn't this change with the Coppermine and Mendocino Slot1 Carts ..pretty sure they were just the 370 CPU slapped onto a SECC2 cart, they shouldn't have cache chips on them. I cant recall if Katmai had separate cache but since it was just a Deschutes overclocked with SSE and better L1 handling I assume it did.
Not that I'm suggesting anyone should do this to a Coppermine or Mendocino Slot1 but in theory you could do it.
Reply 8 of 9, by H3nrik V!
TrashPanda wrote on 2023-03-22, 04:09:
Yes, Katmai did have external cache chips on the Slot 1 PCB, and probably also tag ram. I agree that Coppermine and Mendocinos seems to be just cpus on a slotket. However, they are bga cpus, so not exactly solderable, and whether or not they're 370 ball or something else, I wouldn't know ...
Reply 9 of 9, by Yoghoo
So no point of going that route. Will buy a Socket 370 CPU instead. Thanks all!
