First post, by muon
Hi!
Recently I found a Soyo SY-4SAW motherboard. The board has a old BIOS version (WA1 ). I've seen in this forum there are varios new versions. I tried to flashed a new one and I can't. I use the AWARD flash utility 8.29E. Is it ok? or I need some other version?
The mainboard has a jumper about BIOS ( I don't undestand very well the meaning). Anyway, I've tried the two options with negative results: No flash!!
Does anyone know How I should proceed? Thanks in advanced.
PD: I have a TL866A too. Can I burn the new one BIOS with it? What kind of chip is the BIOS, ( I need to know for choosing in the programmer software)?
