First post, by tsalat
Hi everyone,
I have got this board (https://theretroweb.com/motherboards/s/intel- … 5perl-rock-lake) with no obvious description if it is working or not but the board does not work, surprisingly 😀. The board is equipped with a P4 CPU, no ram, no VGA, and during the start there is no beep code what so ever. The CPU fan will spin, the LED indicating the power to board i lid. I have tried another P4 board and tested the CPU and PSU, tried both in this board as well with the same no-go. The PCI debug card is working on the good P4 board but on this one there is no numbers or activity what's so ever. The capacitors are looking ok, no leakage., and could not find any damage on the board. The BIOS is getting power as well.
Now, I am not sure what to try next, and if it is wort to try changing the capacitors or just forget about the board.
Any idea what to test before I start to change the capacitors?
thx, tomas
Reply 1 of 19, by paradigital
On your diag card, are all the voltage rails present, and what does the reset indicator state? Is the board being held in reset?
Always worth throwing up a few high-res photos of the board, someone might spot something you've missed!
Reply 2 of 19, by Karbist
I suggest measuring the 3 power rails generated by the board,
2.6v memory rail generated by the mosfets near the ram slots
1.5v rail generated by the mosfets near the agp slot.
and cpu vcore.
also board has a switching buck converter on the 2.6v memory rail, so make sure all the caps on that area are good.
Reply 3 of 19, by tsalat
paradigital wrote on 2023-05-22, 06:59:
good point, thank you, the images below.
The voltages are ok on the diag. card, the reset blinks at the beginning then goes off.
The chipset cooler was changed by someone to the one which is there now, not sure why.
https://www.sylex.repository.3d-sphere.com/in … q6ZnMmjEKgLRMAR
https://www.sylex.repository.3d-sphere.com/in … arfSCMy35BLMSHW
Reply 4 of 19, by tsalat
Karbist wrote on 2023-05-22, 07:27:
I suggest measuring the 3 power rails generated by the board, 2.6v memory rail generated by the mosfets near the ram slots 1.5v […]
and cpu vcore.
i have checked he memory and 2,6V
the PCI slot has 3,3V
1,5V rail as well
the mosfet around the CPU (row closer to the connectors): G: 3V, S: 1,5V, D: 12V
the mosfet around the CPU (row closer to the CPU): G:10V, S:0V. D: 1,5V
Reply 5 of 19, by Towncivilian
It looks like one of the yellow capacitors near the CPU has been replaced when comparing your photo to the one on The Retro Web. Try to make sure it is installed in the correct orientation and has the appropriate values.
The fact that it was replaced may also be a hint that the yellow caps are faulty. Are you able to desolder one and check its health?
abit BX-133 RAID, P3-S 1.4Ghz, 768MB PC133, GeForce FX5200, SB16 ISA, 2x40GB RAID1, Sony SDT-9000 & Connor CTD-8000 SCSI DDS2 DAT drives, 3COM 10/100 NIC, Win2k SP4
Depeche Mode Live Wiki
Reply 6 of 19, by tsalat
Towncivilian wrote on 2023-05-22, 10:32:
Do you mean the black one in the tow with the yellow ones? The same is as well on the picture from retroweb, at least I see it here. I have checked the bottom of the board and couldn't see any traces of soldering.
Reply 7 of 19, by Karbist
Since someone has replaced the north bridge heatsink, I would remove the heatsink and inspect the smd component surrounding the chipset and make sure nothing is damaged or knocked off.
also if the original heatsink got hit by something that he had to replace it, there might be cracked soldier joints under the chipset.
Reply 8 of 19, by tsalat
Karbist wrote on 2023-05-22, 12:18:
i have removed the heatsink and there is no obvious damage, like no damage at all. I guess that someone removed the heatsink since the board was not booting, very gently, no marks at the board at all.
i was wondering if the BIOS is okay, I will assume that the intel n82802ab8 is the BIOS chip, next to the buzzer, right? I have never read out such chip, any advice where to get the adaptor to DIP for example?
edit: okay, I have found an adaptor on ali, will need to remove it first but seems like a good approach
any alternative for the intel n82802ab8 ?
thx, tomas
Reply 9 of 19, by tsalat
I have checked the oscillator which is next to the BIOS chip and all looks fine, and thus decided to remove the BIOS.
I am waiting now for the parts to read it out and as well for replacement capacitors, just in case.
Here some pictures from the removal:
https://www.sylex.repository.3d-sphere.com/in … HGZDQHmyTq4oM4g
https://www.sylex.repository.3d-sphere.com/in … 2YDS38L36nAHc5K
https://www.sylex.repository.3d-sphere.com/in … e8QH9LYkZn66RWb
I have made a cradle around the BIOS using kapton a aluminium tape, the aluminium tape was smoking like hell and thus removed it later on.
The BIOS went off easily 350C on the gun with pre-heat at 100C from the bottom and flux. Hopefully it will work at the end 😀
tomas
Reply 10 of 19, by Roman555
IMO it's difficult to spoil a firmware on Intel desktop mainboards - the recovery bios procedure really works there.
What model of P4 did you try with it? I think old Willamate won't run.
Usually ICH5 is weakness of this platform. So check its heating in standby mode and also check resistance of each USB data lines against GND rail (when a power cord is unplugged).
Another weakness - lose contacts of a cpu socket or MCH. Press it slightly and run system to diagnose such failure. Re-flow might help in this case.
Reference board schematics of Intel 865
Good luck!
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 11 of 19, by Dorunkāku
tsalat wrote on 2023-05-22, 06:52:
thx, tomas
I have two of these boards. They don't like to boot. Most other boards will try an fail, but these boards just seem to give up for whatever reason they can find. Be sure to not use CAS 2 memory but use CAS 2.5 or CAS 3. Also both boards had just one bulging capacitor: the big tall one under the RAM slots. I use in a system because it looks so good. If there is something I can test of measure let me know.
Reply 12 of 19, by tsalat
Roman555 wrote on 2023-05-26, 14:17:
IMO it's difficult to spoil a firmware on Intel desktop mainboards - the recovery bios procedure really works there. What model […]
Good luck!
I understand, still, I would like to try that. Maybe a leg was loosen maybe it will not do any difference, we will see. I need 1-2weeks until the stuff will come, than I will try 😀
The CPU is Northwood, 2,6GHz. The other one I have tried was around 2,3GHz I think.
I have tried to press on both the ICH5 and MCH during the power but no difference, re-flow of those two will be the last option.
tomas
Reply 13 of 19, by tsalat
Dorunkāku wrote on 2023-05-26, 16:47:
thx, tomas
At this moment the board is dead, nothing on the debug card at all, so even without RAM there is no life.
I need 1-2weeks to put the BIOS back I will then come back and report, and post as well some positions to measure, maybe there will be something.
thank you, tomas
Reply 14 of 19, by tsalat
thx, tomas
ok, got the parts, was very excited, didnt waited to use the microscope, during the "leg" check of the adaptor for the BIOS teared away a few pads on the board, was jumpering them back, got it done... hopefully I repeaired what I have done at the end, and the adaptor is solidly add to the board. Hence, I can try a different BIOS image.
Any chance to dump the BIOS from your board to make sure it should work?
thx
Reply 15 of 19, by Dorunkāku
I use version P15 for no particular reason. Other versions are available here.
    P15.zip
    351.68 KiB
    30 downloads
Reply 16 of 19, by tsalat
Dorunkāku wrote on 2023-06-08, 12:16:
thx a lot, tried the BIOS, unfortunetelly it behaves the same as before.
I am not sure now what to try next, measured most of the mosfet, and the voltage seems reasonable at drain.
any idea what to try next?
tomas
Reply 17 of 19, by Roman555
tsalat wrote on 2023-06-09, 14:26:
thx a lot, tried the BIOS, unfortunetelly it behaves the same as before. I am not sure now what to try next, measured most of th […]
tomas
Maybe you'll be interested in a topic about ASUS s478 P4P800
ASUS P4P800 disaster
Reply 18 of 19, by tsalat
Roman555 wrote on 2023-06-12, 20:16:
tomas
thank you for your answer. I did not have time to fiddle with the board but I will come back to it as soon as I can.
If it would be dead, well, I will have a spare board, heh
One question though, I have a similar Foxconn board, and I have started to remove the capacitors next to the CPU, however, the solder joints seems to be impossible to be removed. The solder seems to be "strange", temperature 330C will not melt them, adding a fresh solder helps a bit but still the majority of the old one sticks to the copper or capacitor joints, flux dont help either... any trick how to remove it more effective?
thx, tomas
Reply 19 of 19, by Roman555
tsalat wrote on 2023-06-24, 05:43:
thank you for your answer. I did not have time to fiddle with the board but I will come back to it as soon as I can. If it would […]
tomas
thx, tomas
It looks like the board is lead-free and also has massive copper polygons next to the CPU socket. It causes melting point is higher and a soldering iron loses temperature fast. So you are forced to make temperature much higher to melt solder but then there's a danger to damage PCB.
The easiest way is to mix lead-free solder with fusible alloy (Rose's metal or Wood's metal) in soldering joints. But after a de-soldering process you have to remove remains of that metal from holes before installing new caps. Because those alloys is too fragile. Also don't forget using flux even for de-soldering. And also choose a tip massive enough (similar to 900M-T-SK).
As option or addition you may upgrade soldering iron to a more powerful one (eg with T12 Soldering Iron Tips) or use a pre-heater.
Good luck!
