First post, by stu_e_hughes
Hi everyone,
For my XP build I have a Intel® Desktop Board DP43BF which has 4 DDR3 slots with 2 memory channels.
https://ark.intel.com/content/www/us/en/ark/p … ard-dp43bf.html
It can handle up to 1333 mhz so I presume it's best to buy the fastest speed for a gaming setup? Also, is there any advantage to populate each memory module in terms of performance? With the 4GB limit in XP I could add 4 x 1GB sticks and have 2 memory channels having direct access to each stick rather than putting 2 x 2GB sticks in one channel.
Would I have to buy a complete set of sticks for compatibility as well? I know that memory sometimes needs to be from the same batch to be happy. I've seen online batches of 3 sticks together as a maximum so finding 4 x 1GB might actually be a problem unless I mix with another set. But that sounds like a bad idea.
Thanks for your help.
Reply 1 of 8, by zyga64
For dual-channel you need two (with preferably same number of ranks/banks) memory sticks. Same batch is not needed.
More memory stick (above 2) will not give you additional performance gain.
Memory configuration depends on "where" you will put those 2 sticks - on the same channel, or separate.
Moreover some motherboards supports so called "asymmetric" dual-channel - with sticks of different size (i.e. 2GB and 1GB), but I suppose it will be less optimal than normal dual-channel (aka "symmetric").
Four memory sticks will only be needed for quad-channel memory configuration 😀
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 3 of 8, by rasz_pl
Its intel branded board therefore you wont get any options for overclocking/customizing timings. Dont worry about ram too much, its at best ~5% difference in games.
Reply 4 of 8, by pentiumspeed
OS does not care what capacity of motherboard if not supported fully, for example 32bit XP. The bandwidth changes either way when populated one or two slots or even four. Putting in dual or more channel mode helps with igpu the most and some improvements when using a GPU.
There is exceptions, if motherboard cachable range is limited, keep memory size up to this limit. And another is OS limitations like 98 and 98SE as well as 95 causes instabilities if max memory is exceeded.
Cheers,
Great Northern aka Canada.
Reply 5 of 8, by The Serpent Rider
zyga64 wrote on 2023-06-16, 10:21:
That's not true. Memory controller can also do bank interleaving, which is on per channel basis. So for typical dual channel motherboard configuration you need two dual-rank or four single-rank sticks to achieve optimal performance.
Reply 6 of 8, by agent_x007
The Serpent Rider wrote on 2023-06-16, 23:39:
Small thing to add :
LGA 775 chipsets may experience lower OC headroom when fully populated with 4 DIMMs of Dual Rank configuration.
Not that important in this case (since OC is quite limited on Intel board), but might be in someone else's case.
Reply 7 of 8, by zyga64
Thank you ! I didn't know that.
Reply 8 of 8, by pentiumspeed
zyga64 wrote on 2023-06-17, 12:51:
Thanks for clarifying!
Cheers,
