First post, by undeon
- Newbie
I have an SS7 kit and I want to have at least the 1.1 USB ports to use the keyboard and mouse. My motherboard is a PCPartner MVP3 baby AT.
I was searching for information about USB ports and I learned here (thanks, guys) that the best option is to use the onboard USB ports. While searching on our equivalent of eBay, I found the cheapest ASUS USB/MIR 1.11. I asked the seller if he will ship it with the proper cable since he only provided photos of the board. He confirmed that he will.
Looking at the motherboard manual, I noticed that pins 1, 3, 5, and 7 are reversed in relation to pins 2, 4, 6, and 8, and I'm concerned that I might damage anything I connect there.
On the USB board, I can see the pin 1. Using the mark on the board as a guide, is it possible to somehow invert the connector to get both USB ports working? I don't want to modify the cables because I can and will return this board if necessary. However, I would like to test the board beyond the POST screen, install Windows, and benchmark it to ensure that my board is working fine before spending anything else.
