First post, by nfraser01
Hi all
I've just restored a Vaio PCG-R600HMPD but have run into the usual VAIO problem of not being to install an opertaing system on it.
FYI It's a Pentium III/ Windows XP laptop from circa 2002. The problem arises beacuse:
1) Sony have removed all legacy downloads from their support site
2) There is no internal optical drive
3) Another Vaio restore disk cannot be used because Sony has made them model specific
I can't use an OEM or retail Windows XP install disc because the optical drive is an external PCMCIA driven one. Windows XP gets part way through the install and looses the drive as it's missing the correct driver (I presume)
I've tried installing XP on the drive in another machine but it then hangs at boot in the VAIO, even after selecting Safe Mode.
I have the USB floppy for this model so did try a Windows 98 floppy boot/FAT32 isntall , but the playing card that had been jammed into the drive seem to have made it unusable 😒
Does anyone have the CD retore disc set for this Model (or the PCG-R600HMP, which might work)?
Alternatively does anyone have a workaround to get a generic OEM Windows XP to work?
Thanks
