Reply 160 of 178, by CoffeeOne
OK, I found a SC15025CV 110MHz.
Shall I buy it?
    SC15025_15026.pdf
    1.17 MiB
    20 downloads
Reply 161 of 178, by mkarcher
CoffeeOne wrote on 2023-12-07, 20:36:
Shall I buy it?
Looking at the data sheet, the command register of this DAC is again different, so it would need BIOS patches to work in Hicolor / TrueColor modes.
Reply 162 of 178, by Anonymous Coward
Have ICS RAMDACs already been considered? I think the Hercules et4000w32 cards often used AT&T or ICS. The Dynamite Power I have uses an ICS "gendac" in a 68 pin package, but I remember seeing photos of a similar card with a 44pin ICS chip. Not sure if it was "gendac" or not.
Reply 163 of 178, by Anonymous Coward
Anonymous Coward wrote on 2023-12-08, 02:16:
I found something that indicated that chrontel CH8391 might be compatible with AT&T, and it should be available as a 135MHz part in the 44 pin package.
https://stuff.mit.edu/afs/sipb/system/i386_nb … /html/S3-4.html
Reply 164 of 178, by CoffeeOne
Anonymous Coward wrote on 2023-12-08, 07:28:
I cannot find data sheets of the ICS 44 pin chip nor of the Chrontel 8391. The Chrontel 8391 should be available in 110MHz and 125MHz, what is the exact part number of the 2?
The best option seems to be really the orginal AT&T 20C490-11, the 20C491-11 should be 100% compatible, too.
Reply 165 of 178, by Anonymous Coward
The ICS RAMDAC on my Cardex Challenger 9304-20 is an ICS5301-2. I believe it's a 110MHz part, but according to the pdf it was also available as a 135MHz part:
Reply 166 of 178, by CoffeeOne
Anonymous Coward wrote on 2023-12-08, 14:46:
Thx for the datasheets.
The 5301 does not look promising: "Compatible to Tseng Labs" chips, so no.
But maybe the 5300 works on the Ark. 5300-3 seem to be super rare, it might be possible to get a 5300-2.
The CH8391v seems to be available. So there is only one type, which is good for 110MHz or 135MHz (?)
I am not 100% convinced that it is compatible.
Maybe @mkarcher can have a quick look?
Reply 167 of 178, by Anonymous Coward
Probably the ICS5301 isn't viable. But according to the Chrontel datasheet, the 8391 should be compatible with the AT&T 490/491/492.
My impression is that all CH8391s are capable of 135MHz VCLK.
Reply 168 of 178, by feipoa
I have already demonstrated that the ATT20C490-11 can provide a crisp image at 1280x1024x256c at 60 Hz. Since we do not have a VGA BIOS hack to attempt to force 1024x768x65k at 56/60 Hz, what is the benefit on trying to source faster RAMDACs for this card?
Reply 169 of 178, by Anonymous Coward
It was stated that 1024x768x64k @60Hz requires a 130MHz RAMDAC.
Now that a fast enough RAMDAC is potentially available, is the BIOS hack worth the effort?
Reply 170 of 178, by feipoa
I suspect the 110 MHz ATT RAMDACs will suffice for simple testing at 120 or 130 MHz, afterall, the 80 MHz RAMDACs worked for quick tests at 110 MHz. The uncertainty concerning RAMDAC compatibility may be an unwanted variable at this point. Mkarcher did mention that 120MHz may be sufficient by "reducing blanking (works on LCDs, but likely not on CRTs)".
There is a strong possibility that nobody has the time or desire to work on this BIOS hack, thus I was wondering if you guys are getting too far ahead at this point.
On the flip side, I would still be interested if any of these potentially compatible RAMDACs provide an even sharper image than the ATT490, which is already pretty clear.
Reply 171 of 178, by CoffeeOne
feipoa wrote on 2023-12-09, 08:06:
For me it was not about to get something better, something that works would be good enough. I was not able to find something except Upsource, which I don't like.
I now found and ordered a CH1391f.
Reply 172 of 178, by CoffeeOne
CoffeeOne wrote on 2023-12-09, 13:04:
Shit.
I tried a CH1391f. Does not work correctly, even low resolution modes are broken. 640x480 256 colours in Windows 98 shows completely wrong colours.
Reply 174 of 178, by Anonymous Coward
Maybe the "F" in the part number indicates some kind of change. I don't remember seeing that in the datasheet. There is only CH1391i and CH1391v.
Reply 175 of 178, by CoffeeOne
Anonymous Coward wrote on 2023-12-23, 08:17:
Sorry, Typo.
Yes, the card or some chips might be bricked already.
I will change back to the Ark 1491 and check if the card still works.
Reply 177 of 178, by CoffeeOne
feipoa wrote on 2023-12-23, 13:02:
Is there sufficient space for a PLCC-44 socket?
I guess so.
Is this the correct type?
https://www.ebay.at/itm/203060924189
